ADSL Router
Sep 22nd, 2010
/* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin-top:0in; mso-para-margin-right:0in; mso-para-margin-bottom:10.0pt; mso-para-margin-left:0in; line-height:115%; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin;}
Dear all,
I have ADSL line with multiple Public IPs all i need is a router can deal with Multiple IPs and VPN and do i need a modem ?
davidmeiker Wed, 09/29/2010 - 19:39
Hi Omar
First, the ISP have to give you a MODEM that its the resposible to "transform" the analog signal(cable with RJ11 connector) to digital signal(cable with RJ 45 connector), then you have to plug a patch cord throw between the modem and router that you want to buy.
Before you buy a router, You have to test your needs, for example: " What I want to do?" R: I just want to connect a PC to the internet. OK, plug the patch cord between the modem and the PC and ISP will give you a public IP by DHCP, you dont have the NEED to buy a Router.
Ok, But you have buy a router to improve more security, have a wireless LAN and connect some PCs in my Home, I recommend you to buy a Linksys WRT54G Series. Note: The linksys cannot act like a Peer VPN, just passthrough.
Ok, But you have to implement a VPN solution throw ADLS in your business to conect to your othe business in the central park, I recommend you to buy a Router Cisco 805, its especially design to act like a peer VPN to other Router Cisco 805 peer VPN and its easy to configure.
And now if you just want to connect 2PCs through VPN(ADSL) I recommend you: LogMeIn Hamachi.. its Free
Saludos
