Unity Connection 7.1.3 Ports dont fail to second CUCM in group
Sep 23rd, 2010
CUCM 7.1.5 has device pool with two CUCM's this is applied to VM ports in CUCM under device Information.
Issue
When the primary CUCM server is shut down calls cant be made to unity connection
Shouldnt the ports be auto registering to second CUCM in the group?
Any known issues?timers etc
Allan
Aaron Harrison Thu, 09/23/2010 - 01:20
  • Community Spotlight Award,
    Member's Choice, May 2015
You need to manually configure the list of servers CUC uses:
Log into cuadmin, then go to 'Telephony Integrations', then 'Port Group' on the left. CLick the 'Edit' menu, then 'Servers'. Update the list of CCM servers to match your CM Group configuration there.
Aaron
Please rate helpful posts...
