IOS - Help with IPsec L2L VPN with NAT
jesper_petersen
Hello guys
I've been trying to get VPN to work for a specific scenario where I need to do NAT for the VPN traffic to avoid subnet overlapping.
I've found several guides on cisco.com, but all of those that I've found does not allow for (or show how) NAT overload (for internet traffic), which I need for my setup.
http://www.cisco.com/en/US/tech/tk583/tk372/technologies_configuration_example09186a00800b07ed.shtml
http://www.cisco.com/en/US/products/ps5855/products_configuration_example09186a0080a0ece4.shtml
I basically need to know how the configuration looks like when you do static NAT through a VPN tunnel as well as provide internet connectivity using NAT in the same router?
I've attached a drawing that should better explain my needs.
Does anyone have know of a guide that show how to do this?
Best regards
Jesper
You can use static policy NAT to NAT those traffic:
access-list 101 permit ip 10.0.0.0 0.0.0.255 10.30.10.0 0.0.0.0.255
access-list 102 deny ip 10.0.0.0 0.0.0.255 10.30.10.0 0.0.0.0.255
access-list 102 permit ip 10.0.0.0 0.0.0.255 any
route-map policy-NAT permit 10
     match ip address 101
route-map internet-NAT permit 10
     match ip address 102
ip nat inside source static network 10.0.0.0 10.30.10.0 /24 route-map policy-NAT
ip nat inside source route-map internet-NAT interface overload
Hope that helps.
6 Replies 6
Theo Van Wyk
Hello
This is my test config for my lab I can vpn from outside into network but cannot access internet after vpn, must activate spit tunnel
Hope this helps
hostname Inernet
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default group tacacs+ local
aaa authentication login xauthen group tacacs+ local
aaa authorization network groupauthor local
aaa session-id common
clock timezone Harare 2
ip cef
ip auth-proxy max-nodata-conns 3
ip admission max-nodata-conns 3
quit
username xxx privilege 15 password 7 xxxxx
no crypto xauth FastEthernet0
crypto isakmp policy 5
encr aes 256
authentication pre-share
group 2
crypto isakmp client configuration group test
key cisco123
dns 10.10.100.10
domain xxxxxx
pool vpnpool
netmask 255.255.255.0
crypto ipsec transform-set myset esp-aes 256 esp-sha-hmac
crypto dynamic-map dynmap 5
set transform-set myset
crypto map test client authentication list xauthen
crypto map test isakmp authorization list groupauthor
crypto map test client configuration address respond
crypto map test 10 ipsec-isakmp dynamic dynmap
interface Loopback0
no ip address
interface Loopback1
ip address xxxxxx 255.255.255.248
interface Ethernet0
ip address xxxxxx 255.255.255.240
ip helper-address 168.210.2.2
ip nat outside
ip virtual-reassembly
full-duplex
crypto map test
interface FastEthernet0
ip address xxxxxx 255.255.255.252
ip nat inside
speed auto
router eigrp 500
redistribute connected
redistribute static
passive-interface Ethernet0
network 10.30.100.0 0.0.0.3
network 10.60.100.0 0.0.0.7
no auto-summary
ip local pool vpnpool 10.60.100.10 10.60.100.20
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 196.33.38.65
ip http server
ip http authentication local
ip http secure-server
ip nat inside source route-map vpn clients interface Ethernet0 overload
ip tacacs source-interface Loopback0
access-list 101 remark vpn clients=16
access-list 101 deny ip any host 10.60.100.10
access-list 101 deny ip any host 10.60.100.11
access-list 101 deny ip any host 10.60.100.12
access-list 101 deny ip any host 10.60.100.13
access-list 101 deny ip any host 10.60.100.14
access-list 101 deny ip any host 10.60.100.15
access-list 101 deny ip any host 10.60.100.16
access-list 101 deny ip any host 10.60.100.17
access-list 101 deny ip any host 10.60.100.18
access-list 101 deny ip any host 10.60.100.19
access-list 101 deny ip any host 10.60.100.20
access-list 101 permit ip 10.0.0.0 0.255.255.255 any
route-map vpn clients permit 1
tacacs-server host 10.10.100.30 key 7 141A06070D06
control-plane
line con 0
line aux 0
line vty 0 4
login authentication xauthen
transport input telnet
jesper_petersen
Hi Theo
Thank you for your reply. Unfortunately it's not what I'm seeking. I'm seeking information on how to NAT through a LAN-to-LAN VPN connection - not a remote access VPN, as you're using.
But thanks for taking the time to reply
Best regards,
Jesper
Hope that helps.
Hi halijenn
Ahh yes, of course. Still learning
I'm already in the process of trying it out, however i'm struggling with getting the router (ISR1812) to accept the command:
It won't accept the route-map statement - could this be due to software or is it a hardware limitation?
The router is running:
Cisco IOS Software, C181X Software (C181X-ADVIPSERVICESK9-M), Version 12.4(20)T, RELEASE SOFTWARE (fc3)
SiteA(config)#ip nat inside source static network 10.0.0.0 10.30.10.0 /24 ?
  extendable  Extend this translation when used
  mapping-id  Associate a mapping id to this mapping
  no-alias    Do not create an alias for the global address
  no-payload  No translation of embedded address/port in the payload
  redundancy  NAT redundancy operation
  vrf         Specify vrf
Thx
Sorry to disappoint, but seems that the route-map option is only available for one to one static NAT:
ip nat inside source static 10.0.0.1 10.30.10.1 route-map policy-NAT
An option is to configure 254 lines of NAT statements with the route-map to cover the /24 subnet.
Sorry, didn't have any better way.
Hello again Halijenn
Ah yes, I can use that for now as it is only temporary.
Lets hope Cisco implements such a feature in the future
Thanks for all your help.
