Does a CCIE Written renews another CCIE Written ?
Sep 23rd, 2010
Does a CCIE LAB(fail) attempt renews the CCIE Written?
or does a CCIE written in Voice will renew a CCIE Written in R&S ?
Thanks In Anticipation!!!!!!!!
Reza Sharifi Thu, 09/23/2010 - 17:36
Does a CCIE LAB(fail) attempt renews the CCIE Written? No
or does a CCIE written in Voice will renew a CCIE Written in R&S ? Yes
Reza
Brandon Buffin Mon, 09/27/2010 - 11:02
Your first lab attempt must be within 18 months of passing the written exam. Your next lab attempt must be within 12 months of the last failed attempt. The written exam expires after 3 years if you do not pass the lab. You must then retake the written in order to retake the lab exam. So, a lab attempt does not renew the written, but it does extend the timeframe to retake the lab. Also, a CCIE Voice written will not renew a CCIE R&S written. However, once you pass the lab and achieve CCIE, a written exam from any track will renew your CCIE certification. See the following link.
http://www.cisco.com/web/learning/le3/ccie/exam/index.html
Hope this helps.
Brandon
