Multiple webauth login pages per wlan
Sep 23rd, 2010
I know you can use the global override feature on each WLAN to assign a specific login page.  The problem is how do you upload multiple login pages to the controller?  I have 2 wlans and created 2 webauth bundles (login.html, aup.html, logo.jpg).  Tried tarring them as wlan1.tar and wlan2.tar.  I can upload these individiually to controller but only 1 remains when I try and use the WLAN override feature.
I have also tried renaming the files (login1.html, aup1.html, logo1.jpg) and (login2.html, aup2.html, logo2.jpg) then uploading the 2 tar files again.  Same result.
Tried tarring them all together and the controller says "error extracting files".
Anyone got multiple login pages per wlan working?
Controller version 7.0.98.0
firestartest Fri, 09/24/2010 - 04:43
Nevermind.  I sorted it myself.
For anyone interested I had to also upload a login.html page within the tar.  So I had for WLAN1 (login1.html, aup1.html, logo1.jpg) and for WLAN2 (login2.html, aup2.html, logo2.jpg) and also login.html all within the same .tar file.
Trending Topics - Security & Network
