not able to convert 1131 ap LWAPP to autonomous
Sep 23rd, 2010
I have issue for converting lwap to autonomous for lap1131 model.
According to cisco document, i have followed the below procedure :
I  have formatted the flash as well as followed the same procedure
format flash:
reset
  1. Then type in:
set IP-ADDR 10.0.0.1
set DEFAULT_ROUTER 10.0.0.2 (yout laptop/PC IP address)
set NETMASK 255.255.255.0
tftp_init
reset.
but when i give the below command , i am not able to get any response from ap :
tar -xtract tftp://10.0.0.5/ c1240-rcvk9w8-tar.124-10b.JA3.tar flash:
what to do , i am really stuck with that ...
I have attached the details when i could upload the ios which was not valid.
I have downloaded the ios from cisco site .... below the name of file with size 5450.00 KB
file name : ----- c1130-k9w7-tar.124-10b.JDA3.tar
what should i do next ?
Please suggest me for the same.
I am really stuck up with this ..........
It would be appreciatve for getting proper answer.
I am not able to find the root cause of this issue ... whether it is IOS issue or whether it is ap issue ?
please guide me for the same.
Here are the instructions I have always used for all access points.  Works every time.
To use this device as a normal access point, Cisco calls this Autonomous mode.
The IOS image file name is c1130-k9w7-tar.default for 1131.  c520-k9w7-tar.default for 521.
Here is the step by step procedure on how to do the mode button option.
Using the MODE button
You can use the MODE button on 1100 and 1200 series access points to
reload the access point image file from an active Trivial File Transfer
Protocol (TFTP) server on your network or on a PC connected to the
access point Ethernet port.
Note  You cannot use the mode button to reload the image file on 350
series access points. To reload the image file on 350 series access
points, follow the instructions in the "Using the CLI" section.
If the wireless device experiences a firmware failure or a corrupt
firmware image, indicated by three red LED indicators, you must reload
the image from a connected TFTP server.
Note  This process resets all configuration settings to factory
defaults, including passwords, WEP keys, the wireless device IP address,
and SSIDs.
Follow these steps to reload the access point image file:
Step 1  The PC you intend to use must be configured with a static IP
address in the range of 10.0.0.2 to 10.0.0.30.
Step 2  Make sure that the PC contains the access point image file (such
as c1100-k9w7-tar.123-8.JA.tar for an 1100 series access point or
c1200-k9w7-tar.123-8.JA.tar for a 1200 series access point) in the TFTP
server folder and that the TFTP server is activated. For additional
information, refer to the "Obtaining the Access Point Image File" and
"Obtaining TFTP Server Software" sections.
Step 3  If downloaded from Cisco site, rename the access point image file in the TFTP server folder.
For example, if the image file is c1100-k9w7-tar.123-8.JA.tar for an
1100 series access point, rename the file to c1100-k9w7-tar.default.
Step 4  Connect the PC to the access point using a Category 5 (CAT5)
Ethernet cable.
Step 5  Disconnect power (the power jack for external power or the
Ethernet cable for in-line power) from the access point.
Step 6  Press and hold the MODE button while you reconnect power to the
access point.
Step 7  Hold the MODE button until the status LED turns red
(approximately 20 to 30 seconds), and release the MODE button.
Step 8  Wait until the access point reboots as indicated by all LEDs
turning green followed by the Status LED blinking green.
Step 9  After the access point reboots, you must reconfigure the access
point by using the Web-browser interface or the CLI.
Here is the link where you can find this information.
http://cisco.com/en/US/docs/wireless/access_point/12.4_3g_JA/configurati
on/guide/s43trb.html#wp1058472
Ps: Remember to have set up on your windows PC to show the hidden
extensions so when you name the file to .default it is not named
.defult.tar since the PC is hidden the extensions and the process will
not work.
