RSTP or UPLINKFAST instead of standard STP
Answered Question
Sep 23rd, 2010
We have 3 sites, each sites having 28 servers , 10 3550 swittches and 2 3750 switches.
Each server has 2 NIC cards. There are 2 Vlans, each server belong to different VLAN. Each VLAN port of server is directly connected to 3550 switches in order to connect it to IP network. These 3550 switches are in turn connected to 2 redundant 3750 switches.
To route the traffic from a site to another, the 3750 switches are running at L3 using HSRP and EIGRP. For intra-site communication, our 3550 switches and customer 3750 are running at L2 using standard Spanning Tree 802.1D
In each site two 3750 switches are root bridges of VLAN1 and VLAN2
Because of std STP the convegence time is too high around 50 seconds , and its causing problems in the server and database synchonisation.
The possible solutions we have is:- RSTP and enabling uplink fast on 3550 switch.
We can do this only in one site at a time.
Please help me in the following:-
1) What are the risks and conseqences whilie impleneting RSTP and uplink fast.
2)Which of the 2 solutions is better or any better solutions, and how can we implement this, without causing any outage?
Correct Answer by Jon Marshall about 6 years 7 months ago
2) Make sure that, all the trunk ports of 3550 and 3750 switches are operating in Full duplex mode. Or do i have issue the command to force the port as point-to point link, ie "spanning-tree link-type point-to-point" ? Which is the safest option?
By making sure they are full duplex the switch should see them as P2P links.
Please confirm if this proceedure is correct? Usually how long will it take for the RSTP to recalculate parameters and attain stability assuming that there is no topology changes? Anyways am going to request the customer for 1 hour maintenance window.
Procedure looks fine to me. To be honest, assuming you don't have to reload switches, we are talking minutes for it reconverge to a stable network. I suggested an hour because you just never know what might happen and not necessarily with STP ie. you may reload a switch and it does not come up correctly etc. I am not trying to worry you but it's always best to plan for all eventualities.
To enable uplinkfast in all the 10 switches , i have to issue the command "spanning-tree uplinkfast" in global configuration mode right? (or i have to issue the command in  interface level?). I have already enabled "portfast" in access ports fo 3550 switches that is connected to the servers. Does Enabling "uplinkfast" requires it to be changed or i leave it alone? I feel it shouldnt be changed, but still i want to make sure.
You should enable in global config mode. You should leave portfast configured ports as they are. You obviously don't want portfast configured on the switch uplinks.
To implement uplinkfast If i issue the command "spanning-tree uplinkfast" in all 10 switches one after another, how long will it take the network to be stable?
Again, if there are any STP calculations we are talking minutes at most for it to reconverge.
Most probably customer is going to agree only for UPLINKFAST.
If you are going to be getting an outage anyway, and outages are not that easy to come by, i would strongly recommend you advise the customer to go with RSTP and not just uplinkfast. RSTP is a great improvement on STP and not just because it incorporates uplinkfast. If all your switches support it there is no reason not to migrate to it.
BTW its good to know you were a Solaris admin, I am also from the same domain specializng on SUN hardware and Solaris.
I still miss working on Solaris sometimes but i suspect if i was put in front of a Solaris server now i wouldn't haven't a clue what to do
Jon
Overall Rating: 5 (1 ratings)
Jon Marshall Thu, 09/23/2010 - 05:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
You would be much better off migrating to RSTP rather than simply configuring uplinkfast. Uplinkfast has been incorporated into RSTP but so have a few other features eg. backbone fast.  As long as your switches support it RSTP is the way to go.
As for outages i would always plan an outage when dealing with STP because there can always be unforseen consequences. Promising the business no outage and then having STP reconverge will make you look like you don't know what you are doing. If you are straight with the business they will appreciate it.
As for the migration it is relatively straighforward, please see this document for an example -
PVST+ to rapid-pvst
It is very important with RSTP to -
1) make sure spanning-tree portfast is applied on the correct ports
2) make sure that all inter-switch are running at full duplex - basically RSTP needs to see inter-switch links as P2P links and they need to be full duplex.
Jon
socrates_2000 Thu, 09/23/2010 - 06:26
Hi John
              Thanks for the explanations. "spanning-tree portfast" has already been configured on the access ports of the 3550 switches to which servers are directly connected. And for interswitch links, i guess they are already full-duplex by default right?
Issuing the command "spanning-tree mode rapid-pvst" on every switches performs the migration right?
Jon Marshall Thu, 09/23/2010 - 09:06
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi John
Yes, they should be full duplex.
"spanning-tree mode rapid-pvst" does indeed perform the migration although if you have uplinkfast/backbonefast configuration you need to remove that config.
But like i say do this during an outage window.
Jon
socrates_2000 Thu, 09/23/2010 - 10:05
Hi John
             According to cisco technical documentation, the RSTP is backward compatible with STP, however it's mentioned that if the switch running with RSTP detects any other switch with STP, it will make a backward and send STP BPDU messages,and if we enable RSTP in the 2nd switch, the 1st switch will still send STP BPDU till it will be restarted or the STP detection table will be erased !  what are your comments here knowing that in our case we have to enable the RSTP switch by switch ?  Do we have to restart the switch 1 in that case? Whats the strategy for migration? Change the mode to RSTP in the 10 access switches first and then the 2 core switches?
Totally we have 12 switches and 28 servers each with 2 ports in one site. How much time it will take for complete migration (convergence time) approximately so that i can ask the customer for a downtime?
We have totaly 3 sites that are in load sharing mode. Do i need to isolate one of the site while doing the migration? Will there be any impact on the other two sites while doing the migration on one site?
IF customer want to implement only uplinkfast in the 10 access switches? Also how much it will take for migration of 10 access switches from pvst to uplinkfast? how much time would take any 3550 switch with uplinkfast enabled, to converge after a possible crash of any 3750 switch? just to compare with RSTP performance (STP take up to 50 seconds) ?
I am sorry for posting lots of question? Am actually from unix background with some cisco knowldge, but the situation is like i have to take care of this.
Jon Marshall Thu, 09/23/2010 - 10:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi John
Personally i haven't had that issue but if you are taking an outage it should not be a problem reloading switches. If this is an issue then i agree you would be better to do the access-layer switches first then the core switches.
I would ask for an hour per site which gives you a fair bit of leeway if something unexpected happens. Bear in mind the worst case scenario is that you simply end up with STP timers.
How are the sites interconnected ? If they are L3 connected then there is no problem with one site affecting the other. If they are L2 then you can still do one site at a time and all that will happen is that STP timers will be used between sites. One thing to note -
you have 3 switches interconnected sw1 -> sw2 -> sw3 with L2 trunks and 10 vlans. sw1 and sw2 are RSTP capable and sw3 is not. If you have all 10 vlans on all 3 switches then all vlans use standard 802.1d timers. However if you only 2 of the 10 vlans on sw3 and you only have those 2 vlans on sw3 then sw1 and sw2 will use RSTP for the 8 vlans and standard 802.1d timers for just the 2 vlans.
It's pretty much an immediate switch over to the alternate link with uplinkfast. Again i would take an outage because configuring it alters STP values and this can affect your STP topology.
I don't want to sound overcautious with outages but there are things i am happy to configure on a live production network and there are things that i'm not and STP is definitely one of the things i'm not.
No problem with all the questions, that's what these forums are for. I started out as a Unix Solaris admin in IT so i know how you end up doing these sort of things
Jon
socrates_2000 Thu, 09/23/2010 - 13:01
Hi Jon
               The 3 sites are in load sharing mode and redundant pair of 3750 switches in each site are used to connect to other sites using L3 (EIGRP and HSRP).
There are 5 racks/site, Every rack has got 2 3550 switches. Each server has got 2 NIC cards with 2 ports each. There are 2 Vlans, each NIC with two port belongs to one VLAN. One of the port of the NIC is connected to one switch1 and other port to switch2, same way for another NIC. Now all these 3550 have 2 uplinks, one to 3750-1 switch and another to 37500-2 switch.
RSTP
              The following is the proceedure i am going follow is the follow:-
1) Make sure all the access ports of 3550 switch that is connected to the server is configured with "portfast"
3) Then start issue the command "spanning-tree mode rapid-pvst" in global configuration mode in, starting from 3550 access layer switches, and then the two core 3750 switches. If some of the switches are still sending 802.11d BPDUs reload those switches one after the another(i guess i can reload switch2 only after switch1 is  reloaded and back into production?)
UPLINKFAST
To implement uplinkfast If i issue the command "spanning-tree uplinkfast" in all 10 switches one after another, how long will it take the network to be stable?  Just for curiousity, Does uplinkfast enable on switch affects the same on another switch just like STP?
BTW its good to know you were a Solaris admin, I am also from the same domain specializng on SUN hardware and Solaris. But most of the times i am forced to do things on CISCO which am not sure about. Thanks in advance
Ajith
Correct Answer
Jon Marshall Thu, 09/23/2010 - 13:36
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Jon
socrates_2000 Thu, 09/23/2010 - 14:03
Hi Jon
            Thanks for your explanation. I guess after reading some documents and with your explanations i am somehow confident to go ahead with this intervention. I will request the customer for a maintenance window tommorow and i will let you know the outcome of this intervnetion.
Ajith
Jon Marshall Thu, 09/23/2010 - 14:17
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Jon
Ajith
Ajith
Good luck with the change.
Jon
socrates_2000 Fri, 09/24/2010 - 13:12
Hi Jon
           I need to make one more clarification. The trunk ports of 3550 and 3750 are operating in half duplex mode. Before implementing RSTP i have make to sure that they are operating in Full duplex mode right!
What should i be doing? Shall i issue the command  "duplex full" at all the trunk ports to force it to operate at Full duplex or the command "spanning-tree link-type point-to-point" according to the RSTP documentation?
I have another doubt regarding Full duplex and Half duplex. As per my knowledge, in full duplex communications source and destination can communicate simultaneously where as in half duplex either source or destination can communicate at a time. How can  a trunk port work effeciently being configured as Half duplex considering the trunking information flows through these ports?  What are the scenarios where we configure a port as either full duplex or half duplex?
Jon Marshall Fri, 09/24/2010 - 13:30
  • Hall of Fame,
    Founding Member
    2017 LAN, WAN
Hi Jon
You need to make sure your trunk links are working at full duplex before migrating or during the migration. So set the duplex rather than setting the spanning-tree link-type point-to-point.
Trunks will work in half duplex but trunk links generally carry a lot of traffic so you really want them to be full duplex. Just by enabling full duplex this could improve your network performance quite significantly.
Either set bot ends of the link to autobegotiate or hard code both ends but don't hard code one and autonegotiate the other.
Jon
