SHDSL Back-toBack configuration
Sep 23rd, 2010
I have one 1841 (12.4(11)XW10)  and 2811(12.4(15)T7), are installed with WIC-1SHDSL-V3
Please advice me how to configure this interfaces so as to work as CO and CPE.
math
Giuseppe Larosa Thu, 09/23/2010 - 12:02
  • Hall of Fame,
    Founding Member
Hello Ali,
one side needs to be configured as CO
see
http://www.cisco.com/en/US/docs/ios/bbdsl/configuration/guide/bba_atm_shdsl_ps6441_TSD_Products_Configuration_Guide_Chapter.html#wp1132258
you need to use the same VPI/VCI on both sides as no ATM switch is on the middle
notice that you may need also to set the number of wires (2 or 4) to be used as explained in the document above
notice also that command syntax has changed in comparison of older modules see for comparison
http://www.cisco.com/en/US/tech/tk175/tk274/technologies_configuration_example09186a0080135834.shtml
Hope to help
Giuseppe
partner.bkme_2 Fri, 09/24/2010 - 01:41
Hi Giuseppe,
Thanks for the reply.
In 1841
controller DSL 0/1/0
mode atm
line-term co
line-mode 2-wire line-zero
dsl-mode shdsl symmetric annex B
line-rate auto
interface ATM0/1/0
no ip address
no atm ilmi-keepalive
interface ATM0/1/0.1 point-to-point
ip address 5.0.0.2 255.255.255.0
no snmp trap link-status
pvc 2/100
  vbr-nrt 1024 1024
  encapsulation aal5snap
In 2811
controller DSL 0/2/0
mode atm
line-term cpe
line-rate auto
interface ATM0/2/0
no ip address
interface ATM0/2/0.1 point-to-point
ip address 5.0.0.1 255.255.255.0
pvc 2/100
  vbr-nrt 1024 1024
What configuration cause me the interfaces are not coming up.Do I need to use specific cable standard or normal cable.
I tried a cable which Cisco gives, a crosscable along with SHDSL interface pack.
partner.bkme_2 Sun, 09/26/2010 - 01:09
Thank you all...it starts working now I am able to reach next interface.
But it takes long time to coming up after we changed the status
eg."no shut or any status changes.
That will cause my routing protocol convergence as well as all other updates.
Is there anything needs to be done to reduce this amount of time.
