Answered Question
Sep 23rd, 2010
Due to a change in the CUE GUI it is not possible to use the default webinterface to administer the CFA/CFNA/CFB for extensions.
How can the endusers manage these functions while away from the phone?
Installing CCP/CCA/OfficeManager on all desktops is not an acceptable solution.
Thomas Kiel
Removal of Support for Cisco Unified Communications Manager Express GUI Functionality
Beginning with Cisco Unity Express 8.0, the Cisco Unity Express GUI no  longer provides functionality for configuring Cisco Unified  Communications Manager Express. Cisco recommends using Cisco Configuration Professional (CCP) to configure Cisco Unified Communications Manager Express.
Correct Answer by Steven DiStefano about 6 years 3 weeks ago ???
ALso the Phone can do CFAll
Overall Rating: 5 (1 ratings)
tkiel Fri, 09/24/2010 - 23:35
you are right. http:///ccme.html works normally.
But in this instance there is a failure - I will investigate further. The webpage only shows a message in top left corner saying "VIEW WINDOW", thats it.
I tried upgrading a spare UC520 as well, there it all works fine. This must be an upgrade issue.
Thx for the quick reply.
tkiel Tue, 09/28/2010 - 09:16
Found the problem.
Under telephony-service:
directory entry 7 0004523588920 name testperson, "lokalnr"
changed to
directory entry 7 0004523588920 name testperson, lokalnr
and now it works
