ACE: Getting booted off after logging into admin context
AJAZ NAWAZ
Level 5
Level 5
any particular reason why after logging into any context I'm getting kicked off. so for example I telnet to mgt addr configured on admin context and get prompted to enter username followed by password. i enter the correct username and password, but upon doing so i'm getting kicked off.
the username and password is definately right..
anyone seen this before?
yushimaz
Do you try to login with default username/password (admin/admin)?
If so, you may rejected with the following message.
ACE20 login: admin
Password:
Cisco Application Control Software (ACSW)
TAC support: http://www.cisco.com/tac
Copyright (c) 2002-2010, Cisco Systems, Inc. All rights reserved.
The copyrights to certain works contained herein are owned by
other third parties and are used and distributed under license.
Some parts of this software are covered under the GNU Public
License. A copy of the license is available at
http://www.gnu.org/licenses/gpl.html.
Please change the password for admin user.
Admin is allowed only on the supervisor until the password is changed
User 'www' is disabled.Please change the password to enable the user.
Connection closed by foreign host.
If you don't have any message, please check the line with 'show users' command.
If lines become full, you can clear the line with 'clear line [line#]' command.
ACE20/Admin# show users
User                     Context
                Line         Login Time   (Location)    Role    Domain(s)
*admin                   Admin
                ttyS00       Sep 24 02:26               Admin   default-domain
admin                    Admin
                pts/0        Sep 24 02:32 (1.160.0.40)  Admin   default-domain
ACE20/Admin#
ACE20/Admin#
ACE20/Admin# clear line pts/0
ACE20/Admin#
If you cannot login even though lines are not full, please check 'show user-account' command.
Can you  access via ssh with same user?
ACE2/Admin# show user-account
user:admin
        this user account has no expiry date
        roles: Admin
        domain: default-domain
        Context: Admin
user:www
        roles: Admin
        Context: Admin
Yuji
