2921 router can't ping
Sep 23rd, 2010
I have a 2921 Router and I can ping my entire network from the router but nothing can ping it from either side of the router. I know this is something simple but I can't figure it out.
Let me know what stupid thing I missed.
Dan
Jennifer Halim Thu, 09/23/2010 - 06:03
  • Cisco Employee,
Do you have access-list applied to your router interfaces?
ddevecka Thu, 09/23/2010 - 06:07
No ACL. I am running eigrp as well. From the outside I can ping the outside interface but from the inside of the network I can ping everything but the router interface.
Jennifer Halim Thu, 09/23/2010 - 06:18
  • Cisco Employee,
Can you pls share the router config?
If you perform a traceroute, where does it fail?
Could it be any ACL in the path between your inside network and the router?
Jon Marshall Thu, 09/23/2010 - 08:14
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Can you give us some more info. Please answer all the following -
Which IP address on the router are your trying to ping
If it is one of the subinterfaces do you have the client you are pinging from in the correct vlan
what is the default-gateway of the client you are pinging from
Jon
