Replacing a WS-X6148 with a WS-X6748?
Sep 23rd, 2010
Hi, I have two WS-X6148-GE-TX blades in a 6509-E chassis. Due to the limitations I have purchased two replacement WS-X6748-GE-TX blades, my question is, as they are the same types of blades (i.e. - both are 48 port RJ45 Gigabit interfaces) will it just be a case of a straight hot swap of these blades can anyone tell me please?
I will be backing up the config first of course
Many thanks
Jon Marshall Thu, 09/23/2010 - 11:13
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Many thanks
You should be fine hot swapping them and the config should transfer fine depending on the switchport configs eg. QOS settings if you have them could well be different due to the different architecture of the blades.
But like you say, definitely backup configs first !
Jon
nmjones Thu, 09/23/2010 - 13:34
Thanks Jon
There isn't anything complex on these ports as they are purely servers and due to the architecture of the old cards they are fairly sparsely populated at present.
Thanks again.
Nick
Lei Tian Thu, 09/23/2010 - 13:45
  • Cisco Employee,
Hi Nick,
Besides the qos difference as Jon has mentioned. You also want to make sure the IOS version meets the minimum requirement of 6748 LC. If the 6748 LC has DFC, you also want to check the DFC is the same level as the PFC on the sup. I noticed you mentioned it is for server connection, but still want to mention 6748 LC doesn't support POE which 6148 does.
HTH,
Lei Tian
nmjones Mon, 09/27/2010 - 03:19
Hi Lei Tian
Thank you for your answer, I have checked the IOS version and it is later than that on the release notes thankfully
I also haven't ordered the DFC daughter board  so hopefully I won't have any issues with that .
Thanks once again
Nick
Related Content
