calling-info pstn-to-sip issue with two SIP-trunks, CME
Sep 23rd, 2010
Hi all,
I got a Cisco CallManager Express (c2800nm-spservicesk9-mz.124-24.T3.bin), Version 7.1 with two SIP-trunks.
One to the SIP-VoIP-Provider and the other one to a third-party VoiceMail.
The SIP-registration to the VoIP-Provider needs the  "calling-info pstn-to-sip from number set <registration nr.>" under the sip-ua configuration, because the registration-nr. isn't the same as the "real" DID-nr. range.
Unfortunately, the second trunk uses this setting as well and the VoiceMail can't figure out the origin caller-id (it's checking only the from header an not
P-Preferred-Identity number).
Who has such a setup and how can it be done to set the SIP From: information only for one trunk. I use transation-rule for mapping the internal
phone-nr. to the DID-range. This change only affect to the P-Preferred-Identity number.
Norbert
Debug to the SIP-Provider (working fine):
Sep 23 13:23:40.309 METD: //-1/xxxxxxxxxxxx/SIP/Msg/ccsipDisplayMsg:
Sent:
INVITE sip:[email protected]:5060 SIP/2.0
Via: SIP/2.0/UDP 192.168.70.251:5060;branch=z9hG4bK167A1FDA
To: <sip:[email protected]>
Date: Thu, 23 Sep 2010 11:23:40 GMT
Call-ID: [email protected]
Supported: 100rel,timer,resource-priority,replaces,sdp-anat
Min-SE:  1800
Cisco-Guid: 3652879945-3325759967-2288450667-580263944
User-Agent: Cisco-SIPGateway/IOS-12.x
Allow: INVITE, OPTIONS, BYE, CANCEL, ACK, PRACK, UPDATE, REFER, SUBSCRIBE, NOTIFY, INFO, REGISTER
CSeq: 102 INVITE
Max-Forwards: 70
Timestamp: 1285241020
Contact: <sip:[email protected]:5060>
Diversion: <sip:[email protected]>;privacy=off;reason=unconditional;counter=1;screen=no
Expires: 180
Allow-Events: telephone-event
Proxy-Authorization: Digest username="0895330398",realm="asterisk",uri="sip:[email protected]:5060",response="f5d2852ab98ced848917091826682ca6",nonce="4c9b39e8e87d69759ba4ce312cd20f49035986c0",algorithm=md5
P-Preferred-Identity: <sip:[email protected]>
Content-Type: application/sdp
Content-Disposition: session;handling=required
Content-Length: 253
Related Content
