Changing Partern Exchange Server for Unity
Answered Question
Sep 23rd, 2010
Wondering if anyone has had experience with this:
We need to shut down our old 2003 Exchange box and use our Exchange 2007 box exclusively. The issue is our Unity 7 box is using our 2003 Exchange as it's partner server and need to change it to our 2007 box instead.
I've read some documentation on it, but can't find anything specific to our versions listed previously and just wondering if there are any gotchas involved or if this is fairly straight forward.
Any steps you've followed to be successful would be greatly appreciated. Thanks in advance.
Correct Answer by David Hailey about 6 years 7 months ago
Unity 7.x documentation is the same as Unity 5.x - there is no specific 7.x documentation.  The 2 versions are so close that they are interchangeable from a setup/reconfiguration perspective.  Check this link here for info:
http://www.cisco.com/en/US/docs/voice_ip_comm/unity/5x/upgrade/guide/ex/5xcuruge050.html
Hailey
Please rate helpful posts!
Overall Rating: 5 (1 ratings)
Correct Answer
David Hailey Thu, 09/23/2010 - 10:24
  • Purple, 4500 points or more
Hailey
