Question regarding Feature License in Call Manager Express
Answered Question
Sep 23rd, 2010
Customer bought Cisco 2851Voice Bundle w/ PVDM2-48, FL-CCME-100 (Part Number CISCO2851-CCME/K9)
I suppose when you buy a bundle like this, the ISR router has included and loaded (activated) the license to run with 100 IP Phones regardless of the IOS applied (I mean, a IOS with capable with VoIP)
Now, he wants to expand the system to store 150 IP Phones. How could I procced with feaure license?
Is the Feature License (in example FL-CCME-50) a file that should be loaded in the system or is like a PAK in CUCM taht should be uploaded in the Cisco licensing web page?
If was a file, how should load it?
Thanks in advance
Correct Answer by paolo bevilacqua about 6 years 8 months ago
As Rob was telling before (rated his post), CME does not enforce phone licenses in any way.
Overall Rating: 5 (2 ratings)
Rob Huffman Thu, 09/23/2010 - 11:48
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Raul,
Sadly the 2851 cannot support 150 phones   Even with the newest CME licensing scheme,
Licenses are Paper based RTU licenses (Right to Use)
Supported Platforms and Memory Specifications: SCCP IP Phones*
Cisco Platform
Maximum Total1
IP Phones
Maximum
SCCP IP Phones
Maximum Total
Virtual Ports (dns)
Recommended
DRAM
Recommended
Flash Memory
Cisco IAD 2430
25
25
120
256
128
Cisco 1861
25
25
48
256
256
Cisco 2801
25
25
120
256
512
Cisco 2811
35
35
144
256
512
Cisco 2821
50
50
192
256
512
Cisco 2851
100
100
288
384
512
Cisco 2901
35
35
200
512
512
Cisco 2911
50
50
300
512
512
Cisco 2921
100
100
400
512
512
Cisco 2951
150
150
500
512
512
Cisco 3270
48
48
240
256
64 (fixed)
Cisco   3825
175
175
500
384
512
Cisco 3845
250
250
720
384
512
Cisco 3925
250
250
600
1GB
512
Cisco 3925E
400
400
1100
1GB
512
Cisco 3945
350
350
900
1GB
512
Cisco 3945E
450
450
1200
1GB
512
* These memory   recommendations and maximum numbers of IP phones are for common Cisco Unified   CME configurations only. Systems with large numbers of phones and complex   configurations may not work on all platforms and can require additional   memory or a higher performance platform.
1.  Total   number of connected IP phones cannot exceed Maximum Total listed including  SCCP and   SIP phones on the same router.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme80spc.htm
Cheers!
Rob
r.ferrero Fri, 09/24/2010 - 01:42
Thank you Rob,
Sorry, I see there is no possibility to add 50 seat license more in this router.
In another scenario, with the possibility to add more licenses, How could I proceed to do it?
When you said: Licenses are Paper based RTU licenses (Right to Use), Do you mean that shouldn't load any new files in the system? Then, how do CM Express realize that we have added more licenses?
Correct Answer
paolo bevilacqua Fri, 09/24/2010 - 05:00
  • Hall of Fame,
    Founding Member
