Log of LowVirtualMemory
Sep 23rd, 2010
The LowVirtualMemory alert is now activated in a CUCM 7.1. I verified on the SysLog on RTMT, and appears that the process tomcat uses most of the memory (956MB). How can i reduced? Do you have some recomendations?
Regards.
Joseph Martini Thu, 09/23/2010 - 11:05
  • Cisco Employee,
Great job looking into RTMT for what service is using the most virtual memory.  You're already 90% to your fix now.  You can restart tomcat to clear it out which has to be done from the command line with "utils service restart Cisco Tomcat".  You might be able to find a bug based on the full version of call manager in the bug toolkit too if you rather upgrade instead of just having to restart the Tomcat service when that alert occurs.  I don't know how long your system has been up or if this is the first time you've seen that alert.
domingoalberto Thu, 09/23/2010 - 11:12
Thanks Joe,
Also i want to ask you if a restart the tomcat process, it will have affect on the voice service??
And yes it is the firts time is having this alarm.
Joseph Martini Thu, 09/23/2010 - 11:24
  • Cisco Employee,
No restarting Tomcat will not affect voice service.  It's just the web service so your CCMAdmin page, CCMuser, and phone services (they use HTTP) will be unavailable only while the service is restarting (take usually 1 minute to restart or less).
