Provision issue with SPA504G
Sep 23rd, 2010
I am using a 3 tiered provision setup. On the root of my TFTP I have spa504G.cfg:
<?xml version="1.0" encoding="UTF-8" standalone="yes"?>
    <Profile_Rule ua="na">/CiscoVOIP/$PN.xml</Profile_Rule>
    <Syslog_Server ua="na"></Syslog_Server>
    <Debug_Server ua="na"></Debug_Server>
    <Debug_Level ua="na">3</Debug_Level> <!-- options: 0/1/2/3 -->
So then for /CiscoVOIP/$PN.xml I have SPA504G.xml:
    <Profile_Rule_B ua="na">/CiscoVOIP/$MA.xml</Profile_Rule_B>
. -snip-
and then in the same dir I have the config file 0002fdff586d.xml
The issue is this: After a factory reset, the phone will find /spa504G.cfg and apply it. It then reboots but it won't load /CiscoVOIP/$PN.xml. It doesnt even make the request.  If I do a manual reboot of the phone it immediatly loads up /CiscoVOIP/$PN.xml and subsequently /CiscoVOIP/$MA.xml.
I setup a few of these phones a few months ago and it seems to me that I didnt have to manually reboot. Is there a command I am overlooking?
These phones are using firmware 7.4.6.
I have attached the .pcap files of both the factory reset and then reboot. Note that in packet 45 of the factoy reset file is when I fired off the reboot.
Greg P
Overall Rating: 5 (1 ratings)
picturemark Fri, 09/24/2010 - 08:18
Try using a well formed URL in your profile rule.  Judging by your pcap files, this would probably be...
In the pcap files you posted, the phone is sending TFTP requests to IP address, but that is not your TFTP server.  Is that your DHCP server or default gateway?  Also note, I do not see any DHCP reply traffic going from server to client, only requests from client (phone) to broadcast.  Are you using DHCP option 66 or some other method to inform the phone of the TFTP server address?  It's not clear from the pcap how the phone gets its own IP address, or how it ever finds your TFTP server in the first place.
Lastly, I'm not quite sure how to make sense of this, but here is a quote from page 135 of the SPA500 Admin Guide regarding Profile Rule URL interpretation...
"If no protocol is specified, TFTP is assumed. If no server-name is specified, the host that requests the URL is used as server-name."
I dont know what "the host that requests the URL" is referring to, but when you use a fully formed URL as mentioned above, it doesn't matter.
Hope this helps!
micrinservices Tue, 09/28/2010 - 08:53
That seemed to do the trick. I could swear I tried that when troubleshooting this, but I tried it one more time on your suggestion and after a factory reset it loaded all 3 files without a hitch.
Related Content
