WAE-7341 Ios Copy/Upgrade
Sep 23rd, 2010
Hello All,
- I'm having problems to copy an IOS from My FTP server installed on my notebok to the WAE-7341 with Ios version oe7341-4.0.17.14.
- I'm doing this command /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-priority:99; mso-style-qformat:yes; mso-style-parent:""; mso-padding-alt:0cm 5.4pt 0cm 5.4pt; mso-para-margin:0cm; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:11.0pt; font-family:"Calibri","sans-serif"; mso-ascii-font-family:Calibri; mso-ascii-theme-font:minor-latin; mso-fareast-font-family:"Times New Roman"; mso-fareast-theme-font:minor-fareast; mso-hansi-font-family:Calibri; mso-hansi-theme-font:minor-latin; mso-bidi-font-family:"Times New Roman"; mso-bidi-theme-font:minor-bidi;} copy ftp disk 148.92.85.118 / WAAS-4.0.19.14-K9.bin WAAS-4.0.19.14-K9.bin and   I was able to start the ftp download, but the download is timing out after 1/3 of the file transfer.
- Could someone tell me what i'm missing or doing wrong ?
The Image have 254 MB and as you can see i've copied only 179MB
USSMCWAGDRH001#dir
      size          time of last change             name
          1322  Mon Sep 20 17:28:38 2010           UcliEvt.log
     179207920  Tue Sep 21 20:29:57 2010           WAAS-4.0.19.14-K9.bin   <<<<<<<<<<<<<<<
          4096  Thu Oct 22 21:40:00 2009  <DIR>    actona
          4096  Thu Oct 22 20:57:33 2009  <DIR>    core_dir
          4096  Mon Aug  2 10:26:38 2010  <DIR>    crash
             0  Fri Oct 23 01:27:00 2009           db-downgrade.log
          4096  Thu Oct 22 20:57:32 2009  <DIR>    downgrade
          4096  Tue Sep 21 17:01:00 2010  <DIR>    errorlog
          4096  Mon Aug  2 10:27:33 2010  <DIR>    logs
         16384  Thu Oct 22 20:47:03 2009  <DIR>    lost+found
          4096  Wed Aug 11 03:26:01 2010  <DIR>    sa
          8192  Wed Sep 22 12:44:02 2010  <DIR>    service_logs
           350  Mon Aug  2 10:35:33 2010           setup_gen_config.txt
          4096  Thu Oct 22 21:30:48 2009  <DIR>    spool
        154330  Wed Sep 22 12:44:07 2010           syslog.txt
          4096  Thu Oct 22 20:57:13 2009  <DIR>    var
           508  Thu Oct 22 20:57:31 2009           wdd.sh.signed
USSMCWAGDRH001#
Michael Korenbaum Thu, 09/23/2010 - 11:30
  • Bronze, 100 points or more
This sounds like an issue with your FTP server timing out the connection.  You may want to increase the timeout value on the FTP server, or you can enable FTP services on the WAE itself and upload to it.
On the CLI of the 7341 enter the config command inetd enable ftp.
Then from your PC command prompt FTP into the WAE with the admin account and put the file.
Example:
C:\>ftp 14.110.3.19
Connected to 14.110.3.19.
220-Welcome to the PDI WAAS Network.  Please DO NOT make any permanent
220-changes without consulting [email protected]
220-Cisco Wide Area Application Engine
220-
220-
220 pdi-7341-19.pdiwaas.cisco.com FTP server (Version wu-2.7.0(1) Thu Jul 29
04:43 PDT 2010) ready.
User (14.110.3.19:(none)): admin
331 Password required for admin.
Password:
230-User admin logged in.  Access restrictions apply.
230-Device is configured with a (well known) default username/password for ea
of initial configuration.
230 This default username/password should be changed in order to avoid unwant
access to the device.
ftp> bin
200 Type set to I.
ftp> hash
Hash mark printing On  ftp: (2048 bytes/hash mark) .
ftp> prompt
Interactive mode Off .
ftp> mput *.bin
Then you can go back to the WAE and issue the install command, and reload the WAE to complete the upgrade.
Cheers,
Mike Korenbaum
Cisco WAAS PDI Help Desk
http://www.cisco.com/go/pdihelpdesk
P.S. if this answers your quesion, please mark it as answered with a 5.
