WET200 as WAP
Sep 23rd, 2010
We need to use WET200 as Access Points in our wired network with mix wirelss devices. We connected WET200 with network cable with a static ip and used the SSID of our network with a channel gap of 5 from nearby access point but it did not work and our users are unable to connect to WET200. If we change the SSID of WET200 then they are able to connect.
What is the proper way to connect WET200 with our wireless network with cable and use the same SSID?
