Router Redundancy
Answered Question
Sep 23rd, 2010
Hi guys,
I am having 2600 router.I am going to buy a another same model router. I want to build a reduntancy between the two routers
which is the best method to build a reduntancy between two routers.
. i want the following requirements.
1. Router reduntancy
2. Load Balancing
Present configuration in the router:
1.Three MPLS line
2.One Leased Line
3. One Local Network
Thanks in advance.
Correct Answer by Mahesh Gohil about 6 years 5 months ago
Hi naveen,
We have many possibility for router redundancy like hsrp/vrrp/glbp. out of which hsrp and vrrp and similar in functionality.
but the only diference is hsrp is cisco proprietary and vrrp is open standard.
for load balancing glbp is having very good feature and again it is cisco  proprietary.
If your requirement is simply two router with one as active and other is standby then you can go for hsrp/vrrp
or if your requirement is load balancing along with redundancy then you shold go for glbp. please follow as per your requirement
sharing document for glbp for reference.
http://www.cisco.com/en/US/docs/ios/12_2t/12_2t15/feature/guide/ft_glbp.html
Mahesh
Overall Rating: 5 (1 ratings)
Paolo Bevilacqua Fri, 09/24/2010 - 12:18
Have you located a reputable consultant or certified Cisco partner to take care of the configuration ?
naveen_yummy Fri, 09/24/2010 - 12:52
hi poalo,
yes for the changing configuration we are taking the help of the cisco partners
only.
But i want to knw the wat technologies are presently used?
In that which is the preferer to my confiuration?
Pls answer both the above questions,
sumitava123 Fri, 09/24/2010 - 23:40
Hi Naveen ,
Yes that is very much possible. You can configure different technologies to achieve load balancing but the best can be decided only after understanding your requirement and topology.
Sumit
Correct Answer
Mahesh Gohil Sat, 09/25/2010 - 00:01
Hi naveen,
Mahesh
