VPN between two RV042 Routers
Sep 23rd, 2010
Is it possible to create a vpn tunnel between two RV042 routers with only one static address? Looking to connect two networks.  One with a public static address and one with a public dynamic address.  I don't want to use the dynamic dns option.  The Cisco entry level models like the BEFVP41 have the capability of accepting a vpn tunnel from a client with "any" address.  Do these models have this capability?  If so how should I configure them?
Te-Kai Liu Sat, 09/25/2010 - 22:12
  • Gold, 750 points or more
Yes, your scenario is supported. Let's assume RV042-A has static IP and RV042-B has dynamic IP. On RV042-A, you can configure Remote Security Gateway Type as "Dynamic IP + FQDN", where the FQDN string, a shared secret between two routers, does not have to be a valid domain name. On RV042-B, you need to configure Local Security Gateway Type as "Dynamic IP + FQDN" with the same FQDN string.
