Problem in AXL with Cisco Call Manager 4.3
Answered Question
Sep 23rd, 2010
Hello All
I have a problem with Cisco call manager version 4.3 while I am trying to connect via AXL
it reply with with
                              "<h1>Bad Request (Invalid Verb)</h1>"
Really Don't know why als I don't find the document for taht regarding to version 4.3 that talk about AXL Programming Guide
And I will attach the code that I ue if any one had a commect on that:
import java.io.*;
import java.net.*;
public class main
public static void main(String[] args)
  //Declare references
  String sAXLSOAPRequest = null;        // will hold the complete request,// HTTP header and SOAP payload
  String sAXLRequest = null;            // will hold only the SOAP payload
  Socket socket = null;                 // socket to AXL server
  OutputStream out = null;              // output stream to server
  InputStream in = null;                // input stream from server
  byte[] bArray = null;                 // buffer for reading response from server
  String uidpwd="ccmadministrator:Stell@";
  // Build the HTTP Header
  sAXLSOAPRequest = "POST /CCMApi/AXL/V1/soapisapi.dll\r\n";
  sAXLSOAPRequest += "Host: 10.110.200.254:80\r\n";
  sAXLSOAPRequest += "Authorization: Basic "+ new sun.misc.BASE64Encoder().encode(uidpwd.getBytes()) + "\n";
  sAXLSOAPRequest += "Accept: text/*\r\n";
  sAXLSOAPRequest += "Content-type: text/xml\r\n";
  sAXLSOAPRequest += "Content-length: ";
  // Build the SOAP payload
  sAXLRequest = "<SOAP-ENV:Envelope xmlns:SOAP-ENV=\"http://schemas.xmlsoap.org/soap/envelope/\" ";
  sAXLRequest += "xmlns:xsi=\"http://www.w3.org/2001/XMLSchema-instance\" xmlns:xsd=\"http://www.w3.org/2001/XMLSchema\"> ";
  sAXLRequest += "<SOAP-ENV:Body> <axl:getPhone xmlns:axl=\"http://www.cisco.com/AXL/1.0\" ";
  sAXLRequest += " xsi:schemaLocation=\"http://www.cisco.com/AXL/1.0 http://gkar.cisco.com/schema/axlsoap.xsd\" ";
  sAXLRequest += "sequence=\"1234\"> <phoneName>SEP222222222245</phoneName> ";
  sAXLRequest += "</axl:getPhone> </SOAP-ENV:Body> </SOAP-ENV:Envelope>";
  // finish the HTTP Header
  sAXLSOAPRequest += sAXLRequest.length();
  sAXLSOAPRequest += "\r\n\r\n";
  // now add the SOAP payload to the HTTP header, which completes the AXL SOAP request
  sAXLSOAPRequest += sAXLRequest;
  // now that the message has been built, we can connect to server and send it
  try
   socket = new Socket("10.110.200.254", 80);
   out = socket.getOutputStream();
   in = socket.getInputStream();
   // send the request to the host
   out.write(sAXLSOAPRequest.getBytes());
   // read the response from the host
   StringBuffer sb = new StringBuffer(2048);
   bArray = new byte[2048];
   int ch = 0;
   int sum = 0;
   while ( (ch = in.read(bArray)) != -1 )
    sum += ch;
    sb.append(new String(bArray, 0, ch));
   socket.close();
   // output the response to the standard out
   System.out.println(sb.toString());
  } catch (UnknownHostException e)
   System.err.println("Error connecting to host: " + e.getMessage());
   return;
  } catch (IOException ioe)
   System.err.println("Error sending/receiving from server: " + ioe.getMessage());
   // close the socket
   try
    if (socket != null) socket.close();
   } catch (Exception exc)
    System.err.println("Error closing connection to server: " + exc.getMessage());
   return;
So Please I need your help urgent thanks
Correct Answer by sara_rashad about 6 years 10 months ago
Dear Mr Ahmed,
     try the following and it will work with call manager 4.3
     your code needs the HTTP version to be specified in the request.  Therefore, the following line of code in the sample code should be  changed as shown      below to include the HTTP version:
     to
     sAXLSOAPRequest = "POST /CCMApi/AXL/V1/soapisapi.dll HTTP/1.1\r\n";
Overall Rating: 5 (1 ratings)
Correct Answer
sara_rashad Fri, 09/24/2010 - 02:23
Dear Mr Ahmed,
     to
asamir@act-eg.com Fri, 09/24/2010 - 02:31
Thanks Ms. Sara
                    It is worked fine.
Really thank you alot
