Very quick Q about the Aironet 1200 series APs
Sep 23rd, 2010
Hi all,
I have a network of about 20 Aironet 1200's that i need to make a couple of changes on (for all of them).
I need to add a SSID and set that SSID to not be broadcasted.
My questions are: 1) Can i add the SSID in without having to bring the AP down in any way?
2) Where is the command to not broadcast the SSID? (from the GUI and CLi interface)
Surendra BG Sun, 09/26/2010 - 09:06
  • Cisco Employee,
ANS -
Yes you can add the SSID without bringing down the AP...
how ==
from the GUI --
SSID manager >> enter the SSID >> map it to the vlan >> use the corresponding authentication.
Encryption manager >> Selec tthe desired encryption
Network Interfaces  >> Enable the radio.
the above will do it..
ANS ==
From the GUI..
Express security >> SSID >> next to SSID (uncheck BROADCAST SSID).
From CLI -
en
config t
dot11 ssid
no guest-mode
end
wr
this will do it.. Let me know how this works out fot you!!
Surendra
Headley01 Sun, 09/26/2010 - 18:21
Thank you for the reply, however there are two more things i would like to ask..
1) It appears the express security part of your answer will instead create a new SSID entry, and not mask the new SSID from being broadcasting?
2) Is a restart of the Aironet AP required for the new SSID to work?
Surendra BG Sun, 09/26/2010 - 20:38
  • Cisco Employee,
I guess you did not see the GUI correctly.. next to the SSID you will see the box where we enter the SSID name and then followed by a small check box. where we need to check that if we need to broadcast or not if we dont.. check the below link..
https://www.cisco.com/en/US/docs/wireless/bridge/1400/12.3_8_JA/configuration/guide/p38frst.html#wp1050022
Restarting is not required.. the SSID will work if its is configured correctly...
Surendra
Headley01 Mon, 09/27/2010 - 18:34
If i just wanted to keep one SSID, but not broadcast it, what must i do to make that happen?
Surendra BG Mon, 09/27/2010 - 19:18
  • Cisco Employee,
ok.. Gotcha!!!
Then in that case....
SSID Manager >> Select the SSID >> Scrool down oto the bottom of the screen >> We can see Broadcast SSID >> In the drop down make it as NONE >> APPLY.
From the CLI..
en
config t
dot11 ssid
no guest-mode
end
wr
The above will do it..
Surendra
Trending Topics - Security & Network
