Unable to ping management IP on core switch inside the ASA
Sep 23rd, 2010
I have a site with a pair of ASA, a core switch (
4510) and 6 layer switches attached to the core. From outside
, I can ping all devices except the core management IP. I can
get to the core from the firewall or the access switches. icmp any any and replies is permitted on the outside int on the firewall.
Any idea why I can't ping the core switch from outside?
Thanks.
Magnus Mortensen Thu, 09/23/2010 - 18:54
Paul,
     What kind of syslogs do you see when you try to ping from outside the network. Please enable debug level syslogs on the ASA and tell us what syslogs you see. The ASA is very verbose when it comes to telling you why it is not working.
- Magnus
mutabaruka1 Thu, 09/23/2010 - 19:52
Magnus:
I did a capture and I am only getting:
icmp: echo request.
No reply coming back.
nseshan Thu, 09/23/2010 - 19:59
Hey,
I am assuming that you have taken capture on the internal interface that faces the core switch?
If you could run the packet-tracer command as follows, we would be able to roughly determine as to why the packet response is not coming back. Please follow this command:
packet-tracer input icmp 8 0 detailed
Narayanan.
mutabaruka1 Thu, 09/23/2010 - 20:09
Ok. Thanks. I will run the packet-tracer shortly. In meantim
e, here is the capture from the inside int:
31: 19:45:00.575943 802.1Q vlan#201 P0 192.168.1.1.137 > 192.168.1.2.137:  udp 50
    32: 19:45:03.864258 192.168.1.3> 192.168.1.1: icmp: time exceeded in-transit
192.168.1.1 is my pc
192.168.1.2 is the core switch
192.168.1.3 is the inside int of the firewall
mutabaruka1 Thu, 09/23/2010 - 20:28
Here is the packet-trace result:
Phase: 1
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
Additional Information:
Forward Flow based lookup yields rule:
in  id=0x6fb43078, priority=12, domain=capture, deny=false
        hits=636533, user_data=0x6f2e4548, cs_id=0x0, l3_type=0x0
        src mac=0000.0000.0000, mask=0000.0000.0000
        dst mac=0000.0000.0000, mask=0000.0000.0000
Phase: 2
Type: ACCESS-LIST
Subtype:
Result: ALLOW
Config:
Implicit Rule
in  id=0x6f202788, priority=1, domain=permit, deny=false
        hits=55028024, user_data=0x0, cs_id=0x0, l3_type=0x8
Phase: 3
Type: FLOW-LOOKUP
Subtype:
Result: ALLOW
Config:
Found no matching flow, creating a new flow
Phase: 4
Type: ROUTE-LOOKUP
Subtype: input
Result: ALLOW
Config:
in   10192.168.1.1   255.255.255.240 management [The inside int ip is 192.168.1.2 not 192.168.1.1]
Phase: 5
Type: ACCESS-LIST
Subtype: log
Result: ALLOW
Config:
access-group acsnet_ACCESS_IN in interface acsnet
access-list acsnet_ACCESS_IN extended permit icmp any any
access-list acsnet_ACCESS_IN remark ***Developer access
in  id=0x6f2922b8, priority=12, domain=permit, deny=false
        hits=302, user_data=0x6f125910, cs_id=0x0, flags=0x0, protocol=1
        src ip=0.0.0.0, mask=0.0.0.0, port=0
        dst ip=0.0.0.0, mask=0.0.0.0, port=0, dscp=0x0
Phase: 6
Type: CONN-SETTINGS
Subtype:
Result: ALLOW
Config:
class-map class-default
match any
policy-map global_policy
class class-default
  set connection decrement-ttl
service-policy global_policy global
in  id=0x6f3484b8, priority=7, domain=conn-set, deny=false
        hits=156948, user_data=0x6ece3600, cs_id=0x0, flags=0x0, protocol=0
Phase: 7
Type: IP-OPTIONS
Subtype:
Result: ALLOW
Config:
in  id=0x6f204a48, priority=0, domain=permit-ip-option, deny=true
        hits=744719, user_data=0x0, cs_id=0x0, reverse, flags=0x0, protocol=0
Phase: 8
Type: INSPECT
Subtype: np-inspect
Result: ALLOW
Config:
in  id=0x6f203ee0, priority=66, domain=inspect-icmp-error, deny=false
        hits=57183, user_data=0x6f203e10, cs_id=0x0, use_real_addr, flags=0x0, protocol=1
Phase: 9
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
in  id=0x6fb3f5b8, priority=12, domain=capture, deny=false
        hits=1163, user_data=0x6f2e4548, cs_id=0x6f1ba980, reverse, flags=0x0, protocol=1
        dst ip=192.168.1.3, mask=255.255.255.255, port=0, dscp=0x0
Phase: 10
Type: CAPTURE
Subtype:
Result: ALLOW
Config:
out id=0x6f2189a0, priority=12, domain=capture, deny=false
        hits=941, user_data=0x6f2a25d8, cs_id=0x6fbf7a40, reverse, flags=0x0, protocol=1
Phase: 11
Type: FLOW-CREATION
Subtype:
Result: ALLOW
Config:
New flow created with id 840571, packet dispatched to next module
Module information for forward flow ...
snp_fp_inspect_ip_options
snp_fp_adjacency
snp_fp_fragment
snp_fp_tracer_drop
snp_ifc_stat
Module information for reverse flow ...
Phase: 12
Type: ROUTE-LOOKUP
Subtype: output and adjacency
Result: ALLOW
Config:
found next-hop 192.168.1.3 using egress ifc management
adjacency Active
next-hop mac address 5475.d0ef.d37f hits 13506
Result:
input-interface: acsnet
input-status: up
input-line-status: up
output-interface: management
output-status: up
output-line-status: up
Action: allow
nseshan Thu, 09/23/2010 - 20:38
Can you attach a topology diagram or draw out the topology for clarity purposes?
Narayanan.
mutabaruka1 Thu, 09/23/2010 - 20:53
I attached the diagram.
Here the scenario:
From my desk:
- I can ping the firewall fine
-I can ping all layer_2 switches
but I cannot ping the core switch.
From the layer 2 switches:
I can ping the core
I can ping my pc
From the core switch:
I can ping all layer 2 switches
But I can not ping outside the firewall (my pc)
Thanks alot.
Jitendriya Athavale Thu, 09/23/2010 - 21:12
so if i understand you right when you ping your PC from the layer 3 switch behind the core you can ping the PC, but when you try to ping the PC from the core itself it does not work
if i understand you right please check the ip default gateway on your swicth and see if it point to the right device or ip
mutabaruka1 Thu, 09/23/2010 - 21:20
The default gateway is setup fine. the core switch i
s set as the default gateway for the layer 2 switches and they are able
to get outside.
Jitendriya Athavale Thu, 09/23/2010 - 21:26
can you span the switch port connected to asa and confirm if the packets are actually sent out by core, bcoz from the earlier discussion it looks like when we collect captures on the asa interfac we do not see anything,
can you also post the access-list for captures and the sh run int for the interface connected to core
mutabaruka1 Thu, 09/23/2010 - 21:43
here are the config of the interfaces on the core:
Vlan201 is up, line protocol is up
  Hardware is Ethernet SVI, address is 5475.d0ef.d37f (bia 5475.d0ef.d37f)
  Description: management ip
  Internet address is 192.168.1.3
  MTU 1500 bytes, BW 1000000 Kbit, DLY 10 usec,
  Keepalive not supported
  Last input 00:00:00, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/40 (size/max)
  L3 in Switched: ucast: 35486 pkt, 1975044 bytes - mcast: 0 pkt, 0 bytes
  L3 out Switched: ucast: 0 pkt, 0 bytes - mcast: 0 pkt, 0 bytes
     35510 packets input, 1976754 bytes, 0 no buffer
     Received 24 broadcasts (0 IP multicasts)
     4280 packets output, 524513 bytes, 0 underruns
     0 output errors, 0 interface resets
GigabitEthernet1/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is c84c.751d.48b0 (bia c84c.751d.48b0)
  Description: To Firewall
  Keepalive set (10 sec)
  Full-duplex, 1000Mb/s, link type is auto, media type is 10/100/1000-TX
  input flow-control is off, output flow-control is off
  Last input never, output never, output hang never
  Input queue: 0/2000/0/0 (size/max/drops/flushes); Total output drops: 0
  5 minute input rate 2027000 bits/sec, 320 packets/sec
  5 minute output rate 297000 bits/sec, 293 packets/sec
     56976467 packets input, 39831664720 bytes, 0 no buffer
     Received 30027 broadcasts (0 multicasts)
     61034896 packets output, 9453365738 bytes, 0 underruns
     0 lost carrier, 0 no carrier
GigabitEthernet2/1 is up, line protocol is up (connected)
  Hardware is Gigabit Ethernet Port, address is c84c.7549.7870 (bia c84c.7549.7870)
  Description: To firewall fo
  5 minute output rate 2000 bits/sec, 4 packets/sec
     10771 packets input, 735644 bytes, 0 no buffer
     Received 7371 broadcasts (0 multicasts)
     4482092 packets output, 343325250 bytes, 0 underruns
nseshan Thu, 09/23/2010 - 21:51
What i would like to know is, are you able to ping the firewall's next hop on the outside? Also, is there some kind of network running private IP's on the outside of the firewall?
Secondly, is there a NAT rule or access-list statemtn permitting the pings to the core switch on the outside interface of the firewall?
Narayanan.
praprama Thu, 09/23/2010 - 21:48
Based on the attached topology, here is my understanding:
PC(192.168.1.1)-----(NETWORK CLOUD)-----(acsnet)ASA(management)--------------(192.168.1.3)Core
        192.168.1.2
The captures you have attacehd is form the Management interface of the ASA. Please correct me if any of my above assumtions are wrong.
If my assumptions are right, I see tha the IP address of the PC is 192.168.1.1 which is the same as the Management interface network on the ASA and Core witch. The reason why we are seeing the TTL expired message could be due to this conflictng IP address.
According to the ASA the 192.168.1.0 netowrk is on the management interface while the PC is coming in on the acsnet interface.
Let me know if what i have mentioned above is correct!
Prapanch
praprama Thu, 09/23/2010 - 20:49
The captures seems to show that the ASA is sending out "time exceeded in-transit" implying there is somekind of a routing loop in your network. As suggested, please send a line topology with details of from where you are trying to ping to where.
Also, in addition, please attach the sanitized output of "show route" from the ASA.
Prapanch
