Tunnel is not working between asa 5505 and PIX 506
Sep 23rd, 2010
PIX 506e 6.3
access-list 101 permit ip 192.168.1.0 255.255.255.0 192.168.12.0 255.255.254.0
access-list 102 permit ip 192.168.1.0 255.255.255.0 192.168.12.0 255.255.254.0
crypto isakmp policy 13 authen pre-share
crypto isakmp policy 13 encrypt 3des
crypto isakmp policy 13 hash sha
crypto isakmp policy 13 group 2
crypto isakmp policy 13 lifetime 86400
crypto ipsec transform-set MCS esp-3des esp-sha-hmac
isakmp key IT5ngr1 address yyy.yyy.yyy.yyy netmask 255.255.255.255 no-xauth no-config-mode
crypto map outside_map 1 match address 101
crypto map outside_map 1 set pfs group2
crypto map outside_map 1 set peer yyy.yyy.yyy.yyycrypto map outside_map 1 set transform-set MCS
crypto map outside_map interface outside
ASA 5505
access-list 101 extended permit ip 192.168.12.0 255.255.254.0 192.168.1.0 255.255.255.0
access-list 104 extended permit ip 192.168.12.0 255.255.254.0 192.168.1.0 255.255.255.0
tunnel-group xxx.xxx.xxx.xxx type ipsec-l2l
tunnel-group xxx.xxx.xxx.xxx ipsec-attributes
pre-shared-key IT5ngr1
crypto ipsec transform-set MCS1 esp-3des esp-sha-hmac
crypto map name 3 match address 104
crypto map name 3 set pfs group2
crypto map name 3 set peer xxx.xxx.xxx.xxx
crypto map name 3 set transform-set MCS1
crypto map name interface outside
show crypto ipsec sa
in the output there is no IP for the tunnel
show crypto isakmp sa
5   IKE Peer: xxx.xxx.xxx.xxx
    Type    : L2L             Role    : initiator
    Rekey   : no              State   : MM_ACTIVE
There is good response on PIX, I can see both show commands out put on pix.
Please help , Very urgent
Amardeep rana
nseshan Thu, 09/23/2010 - 20:21
Hey,
Can you also attach the outputs of "sh run | in nat" from the PIX and "sh run nat" from the ASA? also please add the outputs of the "sh access-list " along with it.
Narayanan.
Amardeep Kumar Thu, 09/23/2010 - 20:28
PIX
pixfirewall(config)# sh run | in nat
nat (inside) 1 192.168.1.0 255.255.255.0 0 0
nat (inside) 1 0.0.0.0 0.0.0.0 0 0
asa
ciscoasa# sh run nat
nat (inside) 0 access-list 101
nat (inside) 1 192.168.12.0 255.255.255.0
ciscoasa#
asa
access-list 101 line 4 extended permit ip 192.168.12.0 255.255.254.0 192.168.1.0
255.255.255.0 (hitcnt=0) 0x2eb71f45
pix
pixfirewall(config)# sh access-list 102
access-list 102; 1 elements
access-list 102 line 1 permit ip 192.168.1.0 255.255.255.0 192.168.12.0 255.255.
254.0 (hitcnt=2406)
Amardeep Rana
nseshan Thu, 09/23/2010 - 20:37
Hey,
I think you are missing the nat exempt statement on the pix.
Kindly enter the following command:
nat (inside) 0 access-list 102
Narayanan.
Jitendriya Athavale Thu, 09/23/2010 - 21:15
  • Cisco Employee,
hi amardeep,
if this issue is still unresolved, please paste the output of the command show crypto ipsec sa
Amardeep Kumar Fri, 09/24/2010 - 00:33
HI
here is the putput of the command you gave. But I am already running two another tunnel on asa 5505 and they are running properly.
From PIX --
interface: outside
    Crypto map tag: outside_map, local addr. Live IP
   local  ident (addr/mask/prot/port): (192.168.1.0/255.255.255.0/0/0)
   remote ident (addr/mask/prot/port): (192.168.12.0/255.255.254.0/0/0)
   current_peer: ASA Live IP:0
     PERMIT, flags={origin_is_acl,}
    #pkts encaps: 0, #pkts encrypt: 0, #pkts digest 0
    #pkts decaps: 0, #pkts decrypt: 0, #pkts verify 0
    #pkts compressed: 0, #pkts decompressed: 0
    #pkts not compressed: 0, #pkts compr. failed: 0, #pkts decompress failed: 0
   #send errors 0, #recv errors 0
     local crypto endpt.: Live IP, remote crypto endpt.: Remote ASA Live IP
     path mtu 1500, ipsec overhead 0, media mtu 1500
     current outbound spi: 0
     inbound esp sas:
     inbound ah sas:
     inbound pcp sas:
     outbound esp sas:
     outbound ah sas:
     outbound pcp sas:
FROM ASA
ciscoasa(config)# show crypto ipsec sa
interface: outside
    Crypto map tag: name, seq num: 2, local addr: Local IP IP ( Tunnel Already Running)
      access-list outside_2_cryptomap permit ip 192.168.12.0 255.255.254.0 192.1
68.20.0 255.255.255.0
      local ident (addr/mask/prot/port): (192.168.12.0/255.255.254.0/0/0)
      remote ident (addr/mask/prot/port): (192.168.20.0/255.255.255.0/0/0)
      current_peer: Remote Live IP (( Tunnel Already Running)
      #pkts encaps: 1600, #pkts encrypt: 1600, #pkts digest: 1600
      #pkts decaps: 1600, #pkts decrypt: 1600, #pkts verify: 1600
      #pkts not compressed: 1600, #pkts comp failed: 0, #pkts decomp failed: 0
      #pre-frag successes: 0, #pre-frag failures: 0, #fragments created: 0
      #PMTUs sent: 0, #PMTUs rcvd: 0, #decapsulated frgs needing reassembly: 0
      #send errors: 0, #recv errors: 0
      local crypto endpt.: Local IP IP ( Tunnel Already Running), remote crypto endpt.: Remote Live IP (( Tunnel Already Running)
      path mtu 1500, ipsec overhead 58, media mtu 1500
      current outbound spi: 147F5CD2
    inbound esp sas:
      spi: 0xEC5DAE06 (3965562374)
         transform: esp-3des esp-md5-hmac none
         in use settings ={L2L, Tunnel, PFS Group 1, }
         slot: 0, conn_id: 2, crypto-map: name
         sa timing: remaining key lifetime (kB/sec): (4274905/28005)
         IV size: 8 bytes
         replay detection support: Y
    outbound esp sas:
      spi: 0x147F5CD2 (343891154)
         sa timing: remaining key lifetime (kB/sec): (4274904/28003)
         IV size: 8 bytes
    Crypto map tag: name, seq num: 6, local addr: Local IP IP ( Tunnel Already Running)
      access-list 102 permit ip 192.168.12.0 255.255.254.0 192.168.3.0 255.255.2
55.0
      remote ident (addr/mask/prot/port): (192.168.3.0/255.255.255.0/0/0)
      #pkts encaps: 1588, #pkts encrypt: 1588, #pkts digest: 1588
      #pkts decaps: 1539, #pkts decrypt: 1539, #pkts verify: 1539
      #pkts not compressed: 1590, #pkts comp failed: 0, #pkts decomp failed: 0
      local crypto endpt.: Local Live IP ( Tunnel Already Running), remote crypto endpt.: Remote Live IP (( Tunnel Already Running)
      current outbound spi: F7114C6E
    inbound esp sas:
      spi: 0x5F116DB2 (1594977714)
         transform: esp-des esp-md5-hmac none
         in use settings ={L2L, Tunnel, }
         slot: 0, conn_id: 1, crypto-map: chetu
         sa timing: remaining key lifetime (kB/sec): (4274906/27995)
         IV size: 8 bytes
    outbound esp sas:
      spi: 0xF7114C6E (4145106030)
         slot: 0, conn_id: 1, crypto-map: name
         sa timing: remaining key lifetime (kB/sec): (4274898/27993)
         IV size: 8 bytes
thanks
Amardeep
Jitendriya Athavale Fri, 09/24/2010 - 01:21
  • Cisco Employee,
looks like the phase 2 is not up
from which side are you trying to iniate the tunnel and how are you pinging (source ping from interfac eor inside hosts)
give the command management-access inside on both the devices and initiate a ping from both the sides but source it from the inside interface ip
ping inside
see if phase 2 comes up
also run a packet tracer and paste the output from 192.168.1.0 end
packet-tracer in inside icmp 192.168.1.100 8 0 192.168.12.100 detail
very imp: make sure the ip's that you use in packet tracer are not interface ip's
