UCSS-UCN-1-1 was eol/eos what is the replacement ?
Sep 23rd, 2010
Hi all,
As mentioned on tittle, and after spend quite sometime to find what is the replacement on www.cisco.com, I still could not find the answer.
Usually cisco mentioned the product replacement, but for this case they don't.
Could anyone help me ?
Thank you
Rob Huffman Fri, 09/24/2010 - 05:53
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Setiawan,
I believe the change in Part numbers for Unity Connection are as below now
Unified Communications Software Subscription (UCSS)
Cisco Unity Connection = UCSS-UNITYCN
Cheers!
Rob
