CUMA Exchange lookup error
hiepnguyenho
Hello everyone,
I installed CUMA 7 yesterday. When I configured Active Directory Adapter and pressed test button, the output showed:
Configuration Error Details:
Search error.
Here is the screenshot of my CUMA:
I leave all the setting default. Please tell me how to set parameters for CUMA to connect to Active Directory. Thank you very much.
These are another tabs in my configuration:
Javier Cuadros
hi.
i did a fresh install of version 7.0.1.10000-8 then applied the upgrade patche 7.0.2.10000-4
, now when try to test ldap config have the same erroe have any idea of how to setup the eschange loojup under ldap for cuma=?
thanks
mnour401917_2
Did you manage to fix this issue "search error"? i have the same issue.
Please let me know if you have it fixed and how. will be much appreciated if you can help.
Mohammed.
Hi Mohamed,
I fixed this error but I dont really  remember what I changed to solve this problem. These are the screen  shots of my running configuration, hope this help:
Maybe I changed the Admin DN and Contact Adapter Search Base
Hiep Nguyen.
Hi Hiep,
Thanks a lot fo the information. I Chekced all of the Integration information again and tried reconfiguring mobility but with out success.
Is there any thing else that you can suggest?
Mohammed
