Cisco Unified Mobility (CUMA)
Sep 23rd, 2010
Hi people and hope to find you are in good spirits.
What i have is a 7800 server
New build for CUM
Fire her up, insert disc, all goes well then get prompted with the question of
What type of keyboard ? Never seen this before
You have to select English but I only get a few countrys and the closest is US for example
Once this is selected I then get presented with Installation Method
Here I have options
Local CDROM so select this of course
Next I get is NO Driver found?   ODD
So when you select driver you are presented with about 20 to load, have tried all and of course the message is unable to find the devices of the type needed to install
Would be most greatful if any of you wiz kids would know ???
Cheers
Ian
htluo Mon, 10/04/2010 - 12:12
  • Red, 2250 points or more
You must be using a recent model of server (such as 7825-I4) with an outdated version of CUMA (such as 7.1.3.10000).
You need a DVD version of 7.1.3.10101-4.
Michael
http://htluo.blogspot.com
karlareyes Tue, 10/19/2010 - 11:01
Hi, hope you having a good time.
I'm facing the same issue right now the server is 7825-I4, so my doubt is it the iso which you download from CCO account a bootable version (7.1.3.10101-3)?
I need to fix this ASAP but don't wanna waste time if it is non-bootable version
Thanks in advance for your appreciated help
Karla
