IP SLA IS NOT WORKING IN c2600-ik9s-mz.122-46a.bin.
Answered Question
Sep 23rd, 2010
Dear Team,
We have Cisco2621XM router,  where in the below IP SLA is not supporting. Refering the Cisco feature navigator, understood that the below features will support c2600-ik9s-mz.122-46a.bin. But i am not able to execute IP SLA command in config mode.
The below are the features captured from Cisco feature navigator and the same are not supporting in c2600-ik9s-mz.122-46a.bin IOS.
IP SLAs - DHCP Operation
IP SLAs - Distribution of Statistics
IP SLAs - DLSW+ Operation
IP SLAs - DNS Operation
IP SLAs - FTP Operation
IP SLAs - History Statistics
IP SLAs - HTTP Operation
IP SLAs - ICMP Echo Operation
IP SLAs - ICMP Path Echo Operation
IP SLAs - One Way Measurement
IP SLAs - Reaction Threshold
IP SLAs - Scheduler
IP SLAs - SNA LU2 Echo
IP SLAs - SNMP Support
IP SLAs - TCP Connect Operation
IP SLAs - UDP Echo Operation
IP SLAs - UDP Jitter Operation
Correct Answer by Calin Chiorean about 6 years 7 months ago
I've chosen the same features for IP SLA with Features Navigator and the lowest IOS version that support what you need it's 12.3, Enterprise features set.
See attachement.
I have here a 2600 with c2600-i-mz.123-1.bin, and:
(config)#rtr ?
  <1-2147483647>          Entry Number
  key-chain               Use MD5 authentication for RTR control message
  low-memory              Configure low water memory mark
  reaction-configuration  RTR Reaction Configuration
  reaction-trigger        RTR trigger assignment
  reset                   RTR Reset
  responder               Enable RTR Responder
  restart                 Restart an active entry
  schedule                RTR Entry Scheduling
  slm                     Service Level Management
I think you have to upgrade.
Calin
Overall Rating: 5 (1 ratings)
Calin Chiorean Fri, 09/24/2010 - 04:22
  • Silver, 250 points or more
Does it work with rtr command instead of ip sla ?
Cheers,
Calin
Correct Answer
Calin Chiorean Fri, 09/24/2010 - 04:49
See attachement.
(config)#rtr ?
  reset                   RTR Reset
Calin
Sigeesh Sivadasan Sun, 09/26/2010 - 22:54
Hi Calin ,
The configuration is fine after IOS upgrade. Thanks for your inputs.
