how to connect 2 internet links on single router ?
Hello All,
I am having a network with cisco 2811 router (2 FE ports), connected to ASA 5510 firewall which in turn conneted to cisco switch (LAN).
I am having 2 internet links one of 4 MBPS & other is of 2 MBPS. i want to use both of these links to get total 6 MBPS bandwidth.
How can i do that ?
here is my connections :
Router (2 FE ports) :  fa0/0 connected to ISP (4 MBPS)
                              fa0/1 connected to firewall
Firewall :   Ethernet0/0 conneted to router
                 Ethernet0/1 connected to switch.
I am not using 2 MBPS Still. working on 4 MBPS. I want to use them both at a time..
So anyone can tell me how to do that...
Thanks..
Jennifer Halim Thu, 09/23/2010 - 22:42
  • Cisco Employee,
The router should be able to perform load balancing on the 2 default gateways to the 2 ISP links.
