ASR 1002 error message :%IOSXE-4-PLATFORM: R0/0: kernel: mcp: hrtimer_get_softirq_time() not serviced
Sep 23rd, 2010
Hi ,
I got an error message in ASR 1002.
The ASR information:
(1)#show version
Cisco IOS Software, IOS-XE Software (PPC_LINUX_IOSD-ADVENTERPRISEK9-M), Version 12.2(33)XNF1, RELEASE SOFTWARE (fc1)
System image file is "bootflash:packages.conf"
Last reload reason: PowerOn
(2)#show redundancy states
       my state = 13 -ACTIVE
     peer state = 8  -STANDBY HOT
           Mode = Duplex
           Unit = Primary
        Unit ID = 48
Redundancy Mode (Operational) = sso
Redundancy Mode (Configured)  = sso
Redundancy State              = sso
     Maintenance Mode = Disabled
    Manual Swact = enabled
Communications = Up
   client count = 75
client_notification_TMR = 30000 milliseconds
           RF debug mask = 0x0
(3)#show platform
Chassis type: ASR1002
Slot      Type                State                 Insert time (ago)
0         ASR1002-SIP10       ok                    12w2d
0/0      4XGE-BUILT-IN       ok                    12w2d
R0        ASR1002-RP1         ok                    12w2d
R0/0                         ok, active            12w2d
R0/1                         ok, standby           12w2d
F0        ASR1000-ESP10       ok, active            12w2d
P0        ASR1002-PWR-AC      ok                    12w2d
P1        ASR1002-PWR-AC      ok                    12w2d
Slot      CPLD Version        Firmware Version
0         07120202            12.2(33r)XNC
R0        08011017            12.2(33r)XNC
Overall Rating: 5 (1 ratings)
Giuseppe Larosa Fri, 09/24/2010 - 12:47
Hello Rick,
have you received this error only once or multiple times?
the error comes from kernel of OS running on active route processor ( R0/0) and states that a routine hasn't been serviced.
The affected routine is named hrtimer_get_softirq_time() and the name leads to a control process that should get the timestamp of execution of software based interrupts.
Have you experienced any noticeable issue?
Hope to help
ccnarick Sun, 09/26/2010 - 23:08
Hi Giuseppe,
I have two ASR1002 routers.And I got the message twice every device.
I haven't experienced any noticeable issue or other errors.
Do you recommand ?
Giuseppe Larosa Mon, 09/27/2010 - 07:55
Hello Rick,
if it happened only twice on two boxes I would think of a possible SW bug
For the moment I would investigate on bug toolkit and/or I would open a TAC service request.
However, if no real issues the bug may be cosmetic
Hope to help
ccnarick Mon, 09/27/2010 - 19:44
Thank you very much !!
I wii open a TAC case.
If any news,I will update to here.
Related Content
