MLQKVR field corrupt in CDR-file
Sep 23rd, 2010
Hi all
In some of my cdr-files the MLQKvr field contains odd characters, but not all of them only 1 or 2 of the records in the cdr-file.
Have any seen this before?? we get errors when we try to analyse the files in a monitoring tool.
Regards Per
Lakshmi Adapala Fri, 09/24/2010 - 07:31
  • Cisco Employee,
There is a known issue that could cause this, so if you are using CIPC (soft phone) please try upgrading all of them to the latest version.
CSCsm57884    CIPC - Funny Characters in VarVQMetrics Column in CMR file
Symptom: CIPC produces funny characters in the VarVQMetrics column in CMR files, which causes the CMR files to get stuck in the BAD folder.
Conditions:  Seen with IP Commuincator versions 2.1.1 and 2.1.2
Workaround: None
Further Problem Description: MOS LQK Version field inside the VarVQMetrics string is corrupt.
Related Content
