ASA 5520 IP range block or Country IP block
Answered Question
Sep 24th, 2010
hi,
i need help on ASA 5520 and i would like to block countries IP address from the attack, there is any way to block countries ip address or range ip address .
Rabih
Correct Answer by puseth about 6 years 6 months ago
You can get the country ip blocks from here:-http://www.countryipblocks.net/country-blocks/19/
And then you can implement ACL's to block traffic coming in from these subnet range's.
Puneet
Correct Answer by Jennifer Halim about 6 years 6 months ago
Here is the URL on how to check what IP Range the countries has:
http://www.find-ip-address.org/ip-country/
(NB: pls scroll down to the bottom of the page, choose the country and hit "Submit").
Hope that helps.
Overall Rating: 5 (2 ratings)
jdarnellacsmi Tue, 10/07/2014 - 06:48
I've created a script where you chose an authority by selecting in a menu and it'll give you the configuration to drop into the ASA.
https://github.com/in-transit/regional-asa
You can block or allow a specific region if you want. I'll be upgrading it to do specific countries but now it does authorities like ARIN, RIPE, APNIC, etc.
