cisco configuration manager blank screen in the webbrowser
Answered Question
Sep 24th, 2010
i use windows 7 proffesional now on a new computer, my cisco configuaration professional gives a blank screen with java 1.6.0.21
there must be a solution.
you expect a simple solution by google, but that isn't true.
jilles
Correct Answer by chaitram about 6 years 9 months ago
Hi Jilles,
   How are you launching the application? Can you try launching the application by "Right Clicking" on the icon and choose "Run as Administrator" pls?
Let me know if that resolves the launch problem.
Chaitra
Overall Rating: 5 (1 ratings)
Correct Answer
chaitram Tue, 09/28/2010 - 21:49
Hi Jilles,
Chaitra
chaitram Tue, 09/28/2010 - 23:21
Thank you for confirming Jilles. We need to launch this application as Administrator due to some inbuild security settings of Windows 7. This limitation will be removed for launching on Windows in the next version CCP (v2.4).
Chaitra
