Dial-Peer configuration
Sep 24th, 2010
Good day all,
I face a problem with the incoming calls.
I have 4 isdn lines.
1 isdn number is 181
2 isdn number is 030
3 msn 1 --> 472 msn 2--> 006
4 isdn DDI 540-9 (it isn't in use yet)
1st problem
Our customer would like to make 2 groups for the corlist incoming call.
The first group can use only the first and the fourth isdn and the other group only the second and the third.
I have configure it as following but every body can use all the lines.
2nd problem
In the trird line the msn 1 is used by a fax. When I connect this line to the fxs port, the fax dosen't ring. If I connect it from the netmod's ab1 to the fax, it works. The second MSN it is used by an internal phone.
3rd problem
The other problem is in the voice port 1/0/0 used only for the trunk group FCT when somebody calls to a cellular phone. I can make calls via this port, but noboby can call the number of the FCT.
What I am doing wrong?
Thanking you in advance
Ioanna
trunk group FCT
trunk group lawyer1
trunk group lawyer2
trunk group dot
voice translation-rule 500
rule 1 /^01/ /1/
voice translation-rule 600
rule 1 /^000/ /00/
voice translation-rule 900
rule 1 /006/ /1103/
voice translation-profile International
translate called 600
voice translation-profile MoreDigits
translate called 500
voice translation-profile profile
translate called 900
interface BRI1/0
description 181
no ip address
ip flow ingress
isdn switch-type basic-net3
isdn point-to-point-setup
isdn incoming-voice voice
isdn sending-complete
trunk-group dot
interface BRI1/1
description 006
no ip address
ip flow ingress
trunk-group lawyer1
interface BRI1/2
description 030
no ip address
ip flow ingress
trunk-group lawyer2
voice-port 1/0/0
trunk-group FCT
cptone GR
impedance complex2
voice-port 1/0/1
trunk-group FCT
cptone GR
impedance complex2
voice-port 1/0/8
compand-type a-law
cptone GR
connection plar 1000
bearer-cap Speech
voice-port 1/0/9
translation-profile incoming profile
compand-type a-law
cptone GR
bearer-cap Speech
voice-port 1/0/10
compand-type a-law
cptone GR
bearer-cap Speech
voice-port 1/0/11
compand-type a-law
cptone GR
bearer-cap Speech
dial-peer cor custom
name national
name international
name mobile
name internal
name BRI1/0
name BRI1/1
name BRI1/2
dial-peer cor list call-full
member national
member international
member mobile
member internal
dial-peer cor list BRI1
member national
member mobile
member internal
member BRI1/0
dial-peer cor list BRI2
member national
member mobile
member internal
member BRI1/1
dial-peer cor list BRI3
member national
member mobile
member internal
member BRI1/2
dial-peer voice 100 pots
trunkgroup dot
corlist outgoing call-full
destination-pattern 02.........
direct-inward-dial
forward-digits 10
dial-peer voice 101 pots
corlist outgoing BRI2
direct-inward-dial
port 1/0/9
forward-digits 10
dial-peer voice 102 pots
destination-pattern 069........
direct-inward-dial
port 1/0/17
forward-digits 10
dial-peer voice 103 pots
direct-inward-dial
port 1/0/9
forward-digits 10
dial-peer voice 104 pots
destination-pattern 08.........
direct-inward-dial
port 1/0/8
forward-digits 10
dial-peer voice 105 pots
direct-inward-dial
port 1/0/9
forward-digits 10
dial-peer voice 106 pots
translation-profile outgoing International
destination-pattern 000T
direct-inward-dial
port 1/0/8
forward-digits all
dial-peer voice 107 pots
direct-inward-dial
port 1/0/9
forward-digits all
dial-peer voice 108 pots
translation-profile outgoing MoreDigits
destination-pattern 01T
direct-inward-dial
port 1/0/8
forward-digits all
dial-peer voice 109 pots
direct-inward-dial
port 1/0/9
forward-digits all
dial-peer voice 111 pots
destination-pattern 254472
port 1/0/4
dial-peer voice 112 pots
corlist outgoing BRI3
direct-inward-dial
port 1/0/10
forward-digits 10
dial-peer voice 113 pots
direct-inward-dial
port 1/0/10
forward-digits 10
dial-peer voice 114 pots
direct-inward-dial
port 1/0/10
forward-digits 10
dial-peer voice 115 pots
direct-inward-dial
port 1/0/10
forward-digits all
ephone-dn  3  dual-line
number 1002
pickup-group 10
call-forward busy 1000
call-forward noan 1000 timeout 20
corlist incoming BRI2
ephone-dn  4  dual-line
number 1101
pickup-group 10
corlist incoming BRI3
