MGCP CLOCK SOURCE
Answered Question
Sep 24th, 2010
  • Silver, 250 points or more
With H323 you configure clock sources via Network-clock....... and then the priority etc
network-clock-participate slot 1
network-clock-participate slot 2
network-clock-select 1 E1 1/0
network-clock-select 2 E1 2/0
If you have more then one E1 from the same carrier then you set - Or at least I do, or thought you should do, is to add on the following
Controller E1 1/0
Clock Source Line Primary -------1st Clock source
Controller E1 2/0
Clock Source Line-------------------2nd Clock source- used case E1 2/0 goes down
If you have other E1`s connecting to say PABX, then the others are internal to the GW so clock off 1/0 and then 2/0
Question
Now if you use MGCP - do you only set the Clock source on the Web page in CCM to be External for 1/0 and 2/0 and all other internal
How does the GW know the 1st choice clock source is 1/0 and the second 2/0 - is it due to
Do you need to add the commends again for MGCP
Controller E1 1/0
Controller E1 2/0
thanks
Correct Answer by simonmossman about 6 years 9 months ago
WEith MGCP you just set the clock to external from the CCM and the cards will be configured as below:
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
then icrimremental for each E1
Overall Rating: 5 (1 ratings)
Correct Answer
simonmossman Fri, 09/24/2010 - 03:24
