only vlan4 some time goes down for 1 or 2 minutes
Sep 24th, 2010
Hi All,
I am here 3rd time for same problem.
I have 2 site one is IPPL(core switch) and  2nd one is IPGCL(working on  ring tropology ) .IPGCL is connect to IPPL by trunk port. Under IPGCL i have 16 L2 switch that are used ring tropology with IPGCL. now the problem is some time interface VLAN4 goes down for 1 or 2 minute then it automatically goes up.
Could you help me about this problem.
Arup
Overall Rating: 5 (1 ratings)
jasonfmic Fri, 09/24/2010 - 06:02
  • Bronze, 100 points or more
Can you show the output from the following command on your core switch?
sh spanning-tree det | i executing | last change | from
