PoE not working on SPA501G
sjausjausjau
Hi there
I'm currently evaluating different VOIP phones for use. I odered two SPA501G as they offer PoE. However upon connecting the lan port with the switch, I get no connection/boot up of the phones. Neither of them seem to work. I tried three different switches with multiple ports on each, I tried the supplied cable and other ethernet cables. I just can't get it to work.
Is there any special switch/router required for PoE?
Stephan
Rob Huffman
Hi Stephan,
The SPA501G uses;
802.3af-compliant PoE
Are the switches you are using providing 802.3af power?
Cheers!
Rob
http://www.cisco.com/en/US/prod/collateral/voicesw/ps6788/phones/ps10499/data_sheet_c78-548558.pdf
Hi Rob
I don't really know about the switches... I was under the impression that for PoE no special switch was needed. I'll look into that matter.
Stephan
