Cisco ASA 5505 License
Sep 24th, 2010
All,
We have bought a Cisco ASA 5505 firewall with base license. We are confused about the base license provide for 10 users. I am trying to understand what method Cisco uses to calculate license:
For example there are 3 hosts connected to the inside network of ASA currently: Output below:
Result of the command: "show arp"
            inside 130.47.22.3 0012.3f3a.4524 140
            inside 130.47.22.6 001e.3732.4fac 438
            inside 130.47.22.9 0021.861e.c1b6 465
            outside 24.240.94.1 001b.54cb.bed9 2
and non of users are authenticated:
Result of the command: "show uauth"
                                    Current               Most Seen
Authenticated Users     0             6
Authen In Progress       0             64
But when we do show local-host we find out that 6 license are already used.
Result of the command: "show local-host"
Detected interface 'outside' as the Internet interface. Host limit applies to all other interfaces.
Current host count: 6, towards licensed host limit of: 10
Interface outside: 5 active, 33 maximum active, 0 denied
Interface inside: 6 active, 8 maximum active, 0 denied
Interface _internal_loopback: 0 active, 2 maximum active, 0 denied
Can you please explain what method Cisco uses to count the number of license?
praprama Fri, 09/24/2010 - 10:17
What we see in "show local-host" gives the exact picture of what is used to calculate number of inside users. Hope this calrifies it.
Prapanch
dharmendra2shah Fri, 09/24/2010 - 10:21
Prapanch,
I am interested in knowing the method calculation. On what basis it concludes that 6 licenses are already in use where as only 3 hosts are connected?
Dharmendra
praprama Fri, 09/24/2010 - 10:24
What do you notice in the output of "show local-host". You should see IP addresses of all 6 inside users that the firewall sees.
Prapanch
dharmendra2shah Fri, 09/24/2010 - 10:37
Note: I have changed ip addresses for security reasons:
Here is the output of show local-host detail. It is not making sense to me. It says 6 active connections on inside interface where as I only see 1 udp connection.
Result of the command: "show local-host detail"
local host: <172.16.50.80>,
    TCP flow count/limit = 0/unlimited
    TCP embryonic count to host = 0
    TCP intercept watermark = unlimited
    UDP flow count/limit = 1/unlimited
  Conn:
    UDP outside:172.16.50.80/53 inside:172.16.22.9/53114,
        flags -, idle 54s, uptime 54s, timeout 2m0s, bytes 0
local host: <172.16.22.9>,
  Conn:
dharmendra2shah Mon, 09/27/2010 - 05:00
Thanks Jennifer, do you know if Cisco have documented this fact anywhere in their support document pages? If you have the url it will be very helpful.
Thanks, Dharmendra
