SUP720-3B show command for SP-DRAM and RP-DRAM
Answered Question
Sep 24th, 2010
Can someone please tell the show commands for displaying the actual size of SP- and RP-DRAM on a SUP720-3B?
Which DRAM-size is displayed with the show version command? SP or RP?
Thanks for your support in advance.
Martin Funke.
Correct Answer by jasonfmic about 6 years 6 months ago
Try
show platform hardware capacity cpu
Overall Rating: 5 (3 ratings)
Correct Answer
jasonfmic Fri, 09/24/2010 - 12:20
  • Bronze, 100 points or more
Try
MARTIN FUNKE Sat, 09/25/2010 - 10:45
Thanks! That command gives me the needed information.
fyi: I could also get the information with:
remote command switch show version
BR,
Martin Funke.
