any performance data for 6509 16 port 10G--Thx
Answered Question
Sep 24th, 2010
Hi all,
I have a pre-deployment test bed have a  6509 720 sup engine system with a 16 port 10G, and a ASA, a 4900M and VeEX testers. With 2 data streams, 10G traffic  generated from tester, the 10G card in 6509 system only can provide about 50% util bandwidth. Also I can not find where those frames were got dropped.
More detail: ten gi port 3 input X frames, but ten gi port 1 output will be much less (both trunk ports). This only occurs when traffic load higher than 5G traffic.
Is any one know any 10G performance test report?
Also does where we plug the 10G card make diff?
Any info would be greatly appreciated.
Thanks.
gy
Correct Answer by Giuseppe Larosa about 6 years 5 months ago
Hello Gongyuan,
WS-6716 has a 4:1 oversubscription and 4 tengiga ports are served by a single ASIC, only one port of the group of 4 ports can be line rate. So if in your tests you were using ports served by same ASIC your results my be explained by this fact.
see
16-Port 10 Gigabit Ethernet Copper Module
The 16-port 10 Gigabit Ethernet copper module (Figure 1) provides up to 130 10 Gigabit Ethernet copper ports in a single Cisco Catalyst 6509 Switch chassis and 260 10 Gigabit Ethernet ports in a Cisco Catalyst 6500 Virtual Switching System (VSS) 1440 and is primarily designed for data center access with a secondary use case for switch-to-switch connectivity. It consists of 4 port groups of 4 ports each. Users can operate each port group in either oversubscription mode (2 to 4 ports used per port group) or performance mode (1 port used per port group), providing the flexibility to use some ports for connection to servers and other ports for interconnection of switches. In performance mode, up to 4 10 Gigabit Ethernet ports can be used to create a virtual switch link in a VSS.
Hope to help
Giuseppe
Overall Rating: 5 (3 ratings)
Correct Answer
Giuseppe Larosa Fri, 09/24/2010 - 13:01
Hello Gongyuan,
see
Hope to help
Giuseppe
Gongyuan Yao Fri, 09/24/2010 - 13:24
Thank you so much for your quick response.
We have 16-Port 10 Gigabit Ethernet Fiber Module.
According to the spec, if I pick two ports in diff port group, then it will reach full rate (I assume port 1-4 in one group, such as), such as I pick up port 1 and 5 (or 7, etc.).
If we use 4-Port 10 Gigabit Ethernet Fiber Module, that should give us full bandwidth.
Thanks again for your great help.
gy
