Why am I getting this aironet 1400 error
We have put the volt meter to this and its drawing .18 then it spikes to 2.6 goes down to .18. The spikes are random. It forms the association but it says "Association processing" but the error log reads as below.
1Mar 1 08:16:48.903WarningPacket to client 001b.d5f1.9721 reached max retries, removing the client
2Mar 1 08:16:48.854InformationInterface Dot11Radio0, Station bridge 001b.d5f1.9721 Reassociated KEY_MGMT[NONE]
3Mar 1 08:16:48.714InformationInterface Dot11Radio0, Deauthenticating Station 001b.d5f1.9721 Reason: Previous authentication no longer valid
4Mar 1 08:16:48.713WarningPacket to client 001b.d5f1.9721 reached max retries, removing the client
5Mar 1 08:16:48.667InformationInterface Dot11Radio0, Station bridge 001b.d5f1.9721 Reassociated KEY_MGMT[NONE]
6Mar 1 08:16:48.492InformationInterface Dot11Radio0, Deauthenticating Station 001b.d5f1.9721 Reason: Previous authentication no longer valid
7Mar 1 08:16:48.492WarningPacket to client 001b.d5f1.9721 reached max retries, removing the client
8Mar 1 08:16:48.447InformationInterface Dot11Radio0, Station bridge 001b.d5f1.9721 Reassociated KEY_MGMT[NONE]
9Mar 1 08:16:48.268InformationInterface Dot11Radio0, Deauthenticating Station 001b.d5f1.9721 Reason: Previous authentication no longer valid
10Mar 1 08:16:48.268WarningPacket to client 001b.d5f1.9721 reached max retries, removing the client
11Mar 1 08:16:48.228InformationInterface Dot11Radio0, Station bridge 001b.d5f1.9721 Reassociated KEY_MGMT[NONE]
12Mar 1 08:16:48.069InformationInterface Dot11Radio0, Deauthenticating Station 001b.d5f1.9721 Reason: Previous authentication no longer valid
13Mar 1 08:16:48.068WarningPacket to client 001b.d5f1.9721 reached max retries, removing the client
14Mar 1 08:16:48.025InformationInterface Dot11Radio0, Station bridge 001b.d5f1.9721 Reassociated KEY_MGMT[NONE]
15Mar 1 08:16:47.867InformationInterface Dot11Radio0, Deauthenticating Station 001b.d5f1.9721 Reason: Previous authentication no longer valid
16Mar 1 08:16:47.866WarningPacket to client 001b.d5f1.9721 reached max retries, removing the client
17Mar 1 08:16:47.820InformationInterface Dot11Radio0, Station bridge 001b.d5f1.9721 Reassociated KEY_MGMT[NONE]
18Mar 1 08:16:47.680InformationInterface Dot11Radio0, Deauthenticating Station 001b.d5f1.9721 Reason: Previous authentication no longer valid
19Mar 1 08:16:47.680WarningPacket to client 001b.d5f1.9721 reached max retries, removing the client
20Mar 1 08:16:47.636InformationInterface Dot11Radio0, Station bridge 001b.d5f1.9721 Reassociated KEY_MGMT[NONE]
This worked great for 1.5 years and suddenly it is doing this. They are seeing each other and the ssid is identical. Latest firmware, same firmware on both sides.
Serge Yasmine Tue, 10/05/2010 - 09:44
  • Cisco Employee,
Hi Peter,
Packet to client 001b.d5f1.9721 reached max retries, removing the client means that the access point is not receiving an ACK back to a packet it sent to the other bridge, it retried it until removing the client association.
if you say it was working fine and stopped working without any changes then check environment, are the APs still well installed? Did you physically inspect them? We have seen birds nesting on Bridges :-) you will be surprised.
Anything poped in the middle of the line of sight?
If they are getting associated at some stage and then dropping the connection, maybe then do a "sh dot11 asso all" form both of them, while associated, so we know at which signal they are hearing each other.
Serge
Kayle Miller Tue, 10/05/2010 - 09:50
  • Silver, 250 points or more
Peter,
     When you say it's been running for 1.5 years without an issue and now it's not working, but you also said they have the latest firmware on them. So my question is this, did you recently upgrade the firmware on the units and them you began to have this issue? If so I would 1st check the release notes of that code version, secondly I'd be tempted to roll back to the firmware that was running fine..
     Aside from that make sure that the transmit power is the same on both sides of the bridge link, verify the physical installation as reccomended earlier, lastly maybe try another channel to make sure that someone else hasn't put up a bridge that is shooting thru yours on the same channel but with more power.
Hope this helps, Please rate useful posts.
