vg248 unable to call
Sep 24th, 2010
i have a CCM 4.2(3) with a VG248. Recently, the VG248 died so i changed it, and since i can receive calls but i can't call (internal or external) .
But the configuration and the binaries are the same than the older gateway .
Have you got an idea ?
Best regards,
Overall Rating: 1 (2 ratings)
paolo bevilacqua Sat, 09/25/2010 - 04:35
  • Hall of Fame,
    Founding Member
Are you the end user? If so, recommend you locate a reputable consultant, or certified cisco partner to troubleshoot the problem.
c.marcillat Sat, 09/25/2010 - 04:50
i'm not a end user, i am a consultant but the problem is very strange and i don't find a solution !
paolo bevilacqua Sat, 09/25/2010 - 05:10
  • Hall of Fame,
    Founding Member
In any case it's impossible to help you, as you did not give any actual information about the problem, and did not took any trace.
deepagup Sat, 09/25/2010 - 12:09
  • Cisco Employee,
So when you pick the analog phone do you get a dialtone?
If you do - when you try to dial digits do you get a fast busy or any annoucement saying the call cannot be completed as dialed?
Cheers!
c.marcillat Sat, 09/25/2010 - 15:53
I haven't a dial tone, it's strange, it's continuing tone, im sorry for my english but i don't know how to describe this .
It's not a normal dial tone . And when i tried to dial digits nothing happened, as if the digits are not "heard" by the CCM.
I don't know if I am clear ...
Thank you !
Best regards,
deepagup Sat, 09/25/2010 - 22:19
  • Cisco Employee,
This could be a bad phone, cabling, config issue or a bad VG248 port. It will be best to open a TAC case so that the engineer can investigate in detail.
Cheers!
