WIC-1AM-V2 Intermittent on 3945 Router
Sep 25th, 2010
We have a 3945 router with WIC-1AM-V2 installed on slot 0/1/0.
However, we are getting intermittent access. We connected a telephone line on the line port and we are getting different results when we dial-in. I can always connect to it and the router always answers the call but the CLI prompt does not appear all the time. I sometimes get blank screen and sometimes i can configure the router without any issues.
Is there a special command that I need to do on line 19 to fix this or a key stroke that I should do if I cannot connect to it? Thanks.
sh line
   Tty Line Typ     Tx/Rx    A Modem  Roty AccO AccI  Uses  Noise Overruns  Int
      0    0 CTY              -    -      -    -    -     0      0    0/0      -
*     1    1 AUX   9600/9600  -    -      -    -    -     0      1    1/109365   -
  0/0/0    3 TTY   9600/9600  -    -      -    -    -     0      1    0/0      -
  0/0/1    4 TTY   9600/9600  -    -      -    -    -     0      1    0/0      -
  0/0/2    5 TTY   9600/9600  -    -      -    -    -     0      1    0/0      -
* 0/0/3    6 TTY   9600/9600  -    -      -    -    -     0      1 133349/0      -
  0/0/4    7 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
  0/0/5    8 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
  0/0/6    9 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
  0/0/7   10 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
  0/0/8   11 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
  0/0/9   12 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
0/0/10   13 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
0/0/11   14 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
0/0/12   15 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
0/0/13   16 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
0/0/14   17 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
0/0/15   18 TTY   9600/9600  -    -      -    -    -     0      0    0/0      -
* 0/1/0   19 TTY 115200/115200- DialIn    -    -    -     0      0    0/0      -
!Output Cut
John
