8.3 order of nat
sonybabu2k1
I have a doubt regarding order of nat in 8.3. In cisco documentation at one place it says that order is
–Network object NAT—Automatically ordered in the NAT table.
–Twice NAT—Manually ordered in the NAT table (before or after network object NAT rules).
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/nat_overview.html#wp1118634
But in another place in table the order is like:
Section 1 - Twice NAT
Section 2 - Network object NAT
Section 3 - Twice NAT configured in section 3
http://www.cisco.com/en/US/docs/security/asa/asa83/configuration/guide/nat_overview.html#wp1118157
Could anyone please clarify on this ?
Thank you
Jennifer Halim
Hi Sony,
Yes, the documentation is correct.
The NAT order of operation is:
However, within Section 2 itself - Network object NAT - the operation is automatically ordered in the NAT table.
Hope that makes sense.
5 Replies 5
Jennifer Halim
Hi Sony,
Hi halijenn,
Thanks for the reply, so the first one (shown below) is incorrect. right ?
Sony
Yes, you are absolutely right. The Twice NAT section 1 should come first before Network object NAT, as per the following:
I think what the document means to say is (for that particular section of Order of NAT rules) is to use "Network object NAT" first whenever possible, and only use "Twice NAT" if you can't configure it via "Network object NAT".
Thanks halijenn, i think the documentation is a bit confusing. I would appreciate if you could inform documentation people about this.
