dhcp interface
Answered Question
Sep 25th, 2010
An interface has following
interface FastEthernet2/0/24
switchport access vlan 100
switchport mode access
  ip arp inspection trust
no logging event link-status
storm-control action shutdown
spanning-tree portfast
spanning-tree guard root
ip dhcp snooping limit rate 56
vlan 100 is divided into 2 parts- half into dhcp and other half into static ip's.dhcp is till 192.168.100.62 & static range from .63 onwards till .254.
a user using 192.168.100.120 ip plugs in , but is unable to use the network. his arp doesnt appear & is incomplete on the switch.
kindly advise possible way out.
Thank You All.
Correct Answer by Jason Masker about 6 years 6 months ago
You should only need DHCP snooping trust on the port of your DHCP
server but if you have arp inspection enabled you will need 'ip arp
inspection trust' on every port where a host with a static ip
connects. The reason is that arp inspection will filter any arps for
addresses not handed out by DHCP.
Overall Rating: 4 (2 ratings)
Reza Sharifi Sat, 09/25/2010 - 11:06
  • Cisco Designated VIP,
    2017 LAN
What if you delete  "ip arp inspection trust" and clear the arp-cash and test again?
suthomas1 Sat, 09/25/2010 - 18:26
Thanks, i will have these tried & see the status. am i also missing ip dhcp snooping trust?
Correct Answer
Jason Masker Sun, 09/26/2010 - 02:44
  • Bronze, 100 points or more
suthomas1 Sun, 09/26/2010 - 05:25
So , should i only go with ip dhcp snooping trust on the interface and take out rest of them ( inspection, snooping limit ).
Thank You.
