ESX Trunk ports CATOS
Sep 25th, 2010
I used the following command to setup trunk ports to my ESX Server both Broadcom and INtel NICS
set trunk 1/14 nonegotiate dot1q
set spantree portfast 1/14 enable
But when I run
sh trunk
I see that other ports are using "on" instead of "nonegotiate" and also the other trunk ports have native vlan at 1. and this trunk port I configured at native vlan 50. Any idea why?
milan.kulik Sun, 09/26/2010 - 07:29
if I remember correctly from the CatOS times, the other ports are having
set trunk x/y on dot1q
configured probably.
Regarding your second question:
The native VLAN is configured by
set VLAN z  x/y
command in CatOS.
HTH,
Milan
