ccvp......
Sep 25th, 2010
Hi All,
I have cleared cvoice 642-432 (now its 642-436), after few months exams code changed. After that i cleared cipt-1 (642-446). Do i need to clear cvoice 642-636) once again to complete my ccvp or 642-432 is still valid ?
Abhi
Aaron Harrison Sun, 09/26/2010 - 02:42
  • Community Spotlight Award,
    Member's Choice, May 2015
Log into the cert tracker here: http://www.cisco.com/go/certifications/login
It will list your progress towards the current requirements; if you have a check in the appropriate section then the older exam will be fine.
Aaron
Please rate helpful posts...
