mansrini Sun, 09/26/2010 - 16:57
Hi Laith,
You need to enable your wireless/wired supplicant for 802.1x authentication and configure your switch/ WLC ( depending upon wired or wireless) for 802.1x. Typically dot1x works well with a backend radius server and the radius server integrates with AD for credential check. You can search for documentation in cisco site depending upon your switch software/hardware.
Mani
