Supervisor Engine 720 WS-SUP720-3B does not recongnise WS-F6K-DFC3A
Answered Question
Sep 26th, 2010
In my 7606 machine,WS-F6K-DFC3A  daughter card doesnot recognise.It will say powerdown.Can anybody give me a solution.
thanks
Router#sh mod
Mod Ports Card Type                              Model              Serial No.
  1   16  Pure SFM-mode 16 port 1000mb GBIC     WS-X6816-GBIC      SAD052302W3
  2    0  2 port adapter Enhanced FlexWAN        WS-X6582-2PA       JAE1041D2WD
  3    0  2 port adapter Enhanced FlexWAN        WS-X6582-2PA       JAE1041D2UF
  4   48  CEF720 48 port 10/100/1000mb Ethernet  WS-X6748-GE-TX     SAD081201MW
  5    2  Supervisor Engine 720 (Active)         WS-SUP720-3B       SAL1028UKJK
Mod MAC addresses                       Hw    Fw           Sw           Status
  1  0001.6462.48e8 to 0001.6462.48f7   1.7   Unknown      Unknown      PwrDown
  2  0019.55ac.a730 to 0019.55ac.a76f   2.3   12.2(18)SXF6 12.2(18)SXF6 Ok
  3  0019.55ac.dbc0 to 0019.55ac.dbff   2.3   12.2(18)SXF6 12.2(18)SXF6 Ok
  4  000f.2462.be74 to 000f.2462.bea3   1.9   12.2(14r)S5  12.2(18)SXF6 Ok
  5  0016.c847.a0e8 to 0016.c847.a0eb   5.2   8.4(2)       12.2(18)SXF6 Ok
Mod  Sub-Module                  Model              Serial       Hw     Status
  1  Distributed Forwarding Card   WS-F6K-DFC3A       SAD081904XS  2.0    PwrDown
  4  Centralized Forwarding Card   WS-F6700-CFC       SAL0826APSS  2.1    Ok
  5  Policy Feature Card 3             WS-F6K-PFC3B       SAL1028UJ5L  2.3    Ok
  5  MSFC3 Daughterboard           WS-SUP720          SAL1014J8S4  2.5    Ok
Mod  Online Diag Status
Correct Answer by Atif Awan about 6 years 3 months ago
I believe your 7600 (or 6500) is currently running in PFC3B mode so it will not powerup a module with a DFC3A. If you want the DFC3A module to be recognized then you will need to reload the chassis but do keep in mind that the PFC will operate in 3A mode as it is the lowest common mode amongst all installed modules. Any caveats that apply to the PFC-3A mode will apply to your system when it is reloaded and comes in 3A mode.
By the way you can check the operating PFC mode by using the 'show platform hardware pfc mode' command.
Atif
Overall Rating: 5 (1 ratings)
Correct Answer
Atif Awan Sun, 09/26/2010 - 02:16
Atif
WEERAKOO69BA Tue, 09/28/2010 - 02:41
Thanks a lot  Atif,
Exactly righ.I could solve the problem..Thanks alot.Keep it up
senarath
